Question about Hampton Bay 24750 Huntington III Ceiling Fan
My fan wobbles...how do I fix - Hampton Bay 24750 Huntington III Ceiling Fan
  • 3,640 Answers
Switch one blade to another, if that does not work you can measure from the ceiling down to each blade on fan, the blades that are off. you have to remove and shim that blade up or down, put the shim or washer were blades hook on to fan. when the blades are level then it should be ok!! good-luck!
Posted on Oct 23, 2010
SOURCE:
How do I fix wobbly fan blade?
First, Im not a Buick mechanic.
* Call your local Buick dealer for service.
*** Following is for information only ***
* Other than the obvious; cracked fan, mud on fan, etc.
* I found the same question on a forum;
http://www.v8buick.com/index.php?threads/71-skylark-350-motor-with-noisy-fan.204784/
Aloha, ukboy57
Jul 04, 2018 | Vehicle Parts & Accessories
P0495 & p0128
I am thinking you are on the right track. A noisy, wobbly fan has to be replaced and replacing the thermostat could reduce the fan speed as the problems are interrelated.
Nov 15, 2013 | 2005 Chevrolet TrailBlazer
My fan is installed and it wobbles it is anchored properly from the box but the pole has a little play from the top not tightly secured The eletrician had to change the downrod was is on the fan at the...
Hi marilynh57....
Try removing the fan blades and putting them into different positions.
This will sometimes solve your wobbling problem as some fan blades are heavier than others and this causes the wobble you experiance.
Please take time to rate me
Aug 17, 2011 | Vacuums
Fan is wobbling and noisy--cannot figure how to tighten the light fixture part of fan
I have a number of ceiling fans and its usally wise to just check that each blade as all the washes and fixing. As leaving just a washer out can alter the whight and balance.Some noise is to be exspected till they bed in so to speak unless they wobble really bad
Sep 29, 2010 | Hampton Bay 24002 Ceiling Fan
Wobbly ceiling fan
Make sure the blades are not loose.
Jun 11, 2017 | Hampton Bay HL52QV-P-3LC14 Brass Landmark...
My fan is wobbly and it makes a knocking sound when I drive. When I'm stopped or idling it's louder and the engine seems like it's going to shut off. What can be wrong?
If the fan is wobbling, even if the engine was running well, you should fix that. Either the fan clutch has failed or the water pump bearing is bad.
If it comes apart, it will do more damage and cost way more $ to repair.
Other running problem may or may not be related but do that first!!
May 27, 2010 | 2004 Chevrolet TrailBlazer
My radiator fans are wobbly
Well its probably bent and a fan blade is hard to bend back. and make it right. My advise is to buy another one.
Sep 16, 2009 | 2000 Nissan Maxima
The fan blade is loose & wobbles on the shaft on my dodge dakota
Fix it now or forever pick up the pieces...You have one of two problems possibly both...The fan clutch that the fan is bolted to has a bad bearing. replace it Or, the bearing in the water pump has failed. again...replace it. If fan clutch failed carefully check pump ...shaft bearing can be damaged by wobbling assembly. Seriously...don't ignore this if fan gets loose,it will damage far more than the problem you now have!!!
good luck!!
Mar 25, 2009 | 2000 Dodge Dakota Quad Cab
Fan makes noise
try to find the manual through the internet. Look for model number and name of product then click manul to your chosen then it should be no problem to help you find it better!
Jul 18, 2008 | Hampton Bay Cessna 04313 Ceiling Fan
Hampton Bay 24750 Huntington III Ceiling Fan Logo
135 people viewed this question
Top Hampton Bay Dryers Experts
Steve Allison
Steve Allison
Ronald Buckner
Level 1 Expert
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
