Question about Microwave Ovens
Microwave re-started I have a 1991 Panasonic NN-5560A microwave oven that re-started on it's own. I was heating a frozen dinner on medium power for 8 minutes. I left the room while it cooked and heard the five beeps indicating it stopped cooking. After a couple minutes I entered the kitchen to find it had re-started and the clock said 6 minutes left to cook, still on 50% power. My dinner was overcooked with the extra couple minutes, so I know it had completed the previous cycle. Have you heard of this happening and is it time to get a new microwave? We've never had problems with it. How would it re-set itself that way and turn on again?
  • Microwave Ovens Master
  • 9,098 Answers
The Start pad on the keypad may be starting to short. If so, a new keypad (membrane switch) would fix it.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's at
http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The part # needed is A64795790AP "membrane switch" for $46.88 available here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
Panasonic NN-H665BF starts and will run for about 5 seconds and then stops without heating up anything.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [
Aug 07, 2011 | Panasonic NN-S541 Microwave Oven
My Panasonic Model NN-S252WF is not heating properly, it takes about 2x as long as normal to heat something
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 15, 2010 | Panasonic NN-S252WF Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Re: Overheat Microwave or...?
Magnetron (supplies microwave radiation [energy]) or any of the high voltage components internally. More than likely, the HV (high voltage) diode has burned out and is probably cheaper to purchase a new one than have someone repair it unless they can do it for free or you simply pay for the part.
Sep 29, 2008 | Panasonic NN-S540 Microwave Oven
Microwave Oven Panasonic NN-5560A
Chances are your Start key on your keypad has failed.
It is part # A64795790AP "MEMBRANE SWITCH", it runs $46.88 and you can find it here:
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Jun 03, 2008 | Microwave Ovens
Sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
Mar 10, 2008 | Microwave Ovens
Microwave Ovens Logo
109 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
