Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Want to scan to e-mail or computer - HP Officejet 6500 Wireless All-in-One InkJet Printer
  • HP Master
  • 7,733 Answers
Try LINK
Posted on Oct 24, 2010
SOURCE:
How do set up my lexmark pro901 to scan to my pc so that I can email the scans
Make sure the Lexmark Pinnacle Pro901 printer driver is installed on your computer. If you have the install disc that came with your printer, just insert it to your computer hard driver and follow the instructions on your computer screen. You can also the download the printer driver from the Lexmark website at http://bit.ly/d3ftso. Select your operating system > download > execute the file. Again, just follow the instructions on your computer screen.
Note: The install disc contains the Lexmark OCR scan software necessary for scanning documents for editing and saving them as PDF files. The downloaded driver does not contain the OCR software.
To scan to your computer using the printer operator panel:
1. From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2. Touch USB-Connected Computer or the name of a network computer. The local or network computer is the destination that will receive the scan. Wait until the printer has finished downloading a list of the scan applications available on the selected computer.
3. Select an application (in your case your email), and then touch Accept.
4. Select the color, resolution quality and the original image size. If necessary, touch Accept each time you make a selection.
5. Press the start button to start scanning. The scan is complete when the application you selected in step 4 opens on the destination computer, and the scan appears within the application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1. Click Start.
2. Click All Programs or Programs, and then select the printer program folder from the list.
3. Select Printer Home.
4. Choose your printer from the printer drop-down list.
5. Click Email, and then select Photo, Document or PDF.
Note: You can select Document only if an OCR application is stored on your computer. Scanning starts and the scan progress dialog appears.
6. When the scan is finished, a new e-mail message is created with the scanned document automatically attached.
7. Compose your e-mail message. Note: If your e-mail program does not open automatically, then you can scan the document to the computer and then send it through e-mail as an attachment.
For Mac:
1. From the Finder desktop, double-click the printer program folder.
2. Double-click the printer Center to open the All-In-One Center.
3. From the "What is being scanned?" menu on the main screen, select a document type.
4. From the "How will the scanned image be used?" menu, choose To be viewed on monitor/web page.
5. From the "Send scanned image to" menu, choose an application.
6. Click Scan.
7. Retrieve the scanned image from the application, and then send it through e-mail as an attachment.
I hope this information has been helpful.
Sep 19, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Can lexmark x1160 printer scan to computer or e-mail
Most multi-function scanner printer cannot scan to e-mail. They can scan and fax if it has a phone line connection.
You can scan and save the scanned doument as an image file and then send an e-mail with the image file as a file attachment.
Jul 07, 2011 | Office Equipment & Supplies
How does the 1210 scanner work with Windows 7? I have downloaded the driver for the printer and it works ok, but I cannot use the software for the printer. The copier and the scanner work, but i cannot...
You will have to do a two step process to send a scanned document or image by email; the scan to e-mail button won't work. Scan using either Windows Fax and Scan or Paint. Save your file. Then start (Compose/Write) an e-mail to the person you need to send the document. Click Attach and browse to the location where the scan was saved. The default folder is C:/Users/<user_name>/My Documents/Scanned Documents . Click OK after selecting that image. Finish writing your e-mail and send it.
If you'd like to automatically open the e-mail program, browse to the folder where you saved the fax from Computer (Start button) and right click on the image. Choose Send to Mail Recipient. The new mail compose window should open.
I hope this helps.
(a program like PaperPort may let you send to e-mail recipient without the extra step; however I'm not sure of the details.)
Mar 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
How to scan to e-mail
Hi this is kamal....
pls read and do these steps carefully.. definitely u will get solution..
SCAN DIRECTLY TO E-MAIL FROM THE MACHINE- The direct "scan to e-mail" function was the hardest thing to setup. You have to have an actual POP e-mail address for your scanner, which is how it sends PDFs or JPGs of TIF files directly from the box. Getting an e-mail account setup is simple enough, but the control panel won't recognize the servers by name, for example standard pop mail server names list POP.GMAIL.COM. Instead you have to actually convert the server names into IP addresses (I found a website somewhere that did this) and insert that IP address into the control panel.
Once setup, the scan-to-email function works just as you'd expect. But it requires way too many key strokes on the machine to actually send the document. "Are you sure, Are you really sure, Are you really really sure?" (not exact quotes, but you get the idea)
I'm in my late-twenties with a background in the tech field, yet programming this direct-to-email function had me cussing and pulling my hair out. I imagine most people will setup the network scanning application and stop there. The network scanning application is actually a lot more versitile than the direct scan-to-email, even though it requires you to have your computer turned on. But using the network scanning the document just appears, then you can forward it to whatever e-mail you want via your computer (and keep your hair).
best regards
kamal singh
Oct 08, 2009 | Samsung CLX 3160fn All-In-One Printer
How to scan a hard copy, and send in an email?
Install the Control Center CC3, if it is not already installed. Connect the MFC-5460CN to the computer. Open the CC3 software. Click the Scan button. You will have the choice to Scan to Picture, Scan to OCR, Scan to E-mail, or Scan to file.
You click to E-mail. The MFC scans the document and opens the default E-mail program (Outlook, Outlook Express), attaches the scanned picture and all that is left for you to do is to supply the E-mail address where the document is to be sent.
If you have problems doing that, scan to file then open the E-mail client to create a new message and attach the file you scanned.
Hope it helps.
Sep 28, 2009 | Brother MFC-5460CN InkJet Printer
I have a H.P.PhotosmarC5180. How do I scan to my
hi
go in your my computer and there you will see hp scanning device which is photosmart select the scan and follow the wizard and you will be able to scan the document, but once its complete save it on your machine and then send the mail as an attachment.
Mar 24, 2009 | HP Office Equipment & Supplies
Scan and e-mail
hi..place the paper in the printer,then go
to printer setting ,there u will get a option
for scan.Select that option and click ok.
It starts scanning,then it asks where to save
the scanned paper.you choose your location.
Then u can e-mail it as u do.
thank u..
Feb 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do i scan document to e-mail
Answer - scan doc to e-mail out. You need equipment (scanner, copier/scanner/printer, etc. to scan your doc. The software will ask you where you want to store it on your computer. Then go to e-mail program and click on new mail. After you fill out "to:", "regarding" etc. find the tab for "attachment". That tab will allow you to search your computer for doc you want to attach and send. Then send! Good luck! Va.
Nov 05, 2008 | Lexmark Office Equipment & Supplies
Brother MFC 9840CDW
I'm trying to get my Brother MFC set up to scan to e-mail and open a new email with the scanned document attached. I am independant and not connected to any other service as I am a one man user operator.
Sep 10, 2008 | Brother Multi-Function Center MFC-240C...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
21 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
