Question about Friedrich Heating & Cooling
Need model # on kstar air conditioner - how do i find it?
Window model - need new 14" wide filter that has 2 rows of 5 panels. also need two window inserts. thanks
Laurie
5 Suggested Answers
chillmaster
  • 104 Answers
SOURCE: Fedders window model A6Y12F2B "New Unit",,only
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Posted on Jun 23, 2008
  • 5 Answers
SOURCE: Everstar portable air conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Posted on Sep 12, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
  • 189 Answers
SOURCE: air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Posted on Apr 14, 2009
mcdevito75
  • 1970 Answers
SOURCE: Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Posted on Jun 24, 2010
I need to replace overload switch in friedrich air conditioning model CP15G10
The part number is a Klixon MRA12107-117 this can be bought at any supply house
May 30, 2014 | Friedrich KStar KQ06J10 Air Conditioner
Friedrich kq06j10 air
should be right in front of cover in front. either the grille in front pops off or whole front comes off
Aug 10, 2013 | Friedrich KStar KQ06J10 Air Conditioner
Can i turn my older kstar in window air conditioner on its side to fit in a smaller window or will this cause problems.
No!!!!!!!!!!!!!!!!!!!!!!!!!!! Dont do that the compressor has to be level unless your trying to start a fire then do that.
Jul 06, 2011 | Heating & Cooling
I have a Freidrichs Kstar wall ac. It's about 15 years old. Need a filter for it and I don't have the model number. Any suggestions?
If I recall correctly, your model uses a foam type, washable filter. If that's the case, you can pickup one at just about any hardware store or home center. These are the ones that you can cut to fit, if necessary.
Hope this helped you. Please let me know. Thanks.
Jun 01, 2011 | Friedrich KStar KQ06J10 Air Conditioner
What is the size of this air conidotioner model number ESA3109-L
Do you mean the amount of energy that it uses? It is a 10,200 BTU air conditioner and is recommended for a space of 475 sq. ft.
If you mean the dimensions of the window unit itself when installed, then the space between the window casings must be between 24 1/2" and 38" wide. The height is 14 9/16" and the depth is 20 5/32". The AC unit itself is 14 3/8" x 19" x 20 5/32". See page 15 of the manual (16 of the pdf) for the entire set of dimensions.
Retrevo has the manual avaiable here: http://www.retrevo.com/support/Haier-ESA3109-L-Air-Conditioners-manual/id/23148bh150/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
May 25, 2011 | Heating & Cooling
My Rinnai heater starts then stops after 5 -10mins flashing 14.
14 is an error code alerting you that the unit is heating up too hot. Check the air filter and make sure it is clean. You may have to take the front panel off and inspect the burner area for any signs of overheating. Remove the trim panels closest to the wall and clean out any debris from behind the heater. Let us know next time what model you have. Good luck!
Mar 30, 2011 | Rinnai Heating & Cooling
Where can i buy replacement filters?
have you tried there web page?adrian,,,,,,,,
Sep 02, 2010 | Friedrich KStar KQ06J10 Air Conditioner
Jun 22, 2010 | Heating & Cooling
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
Filter
Check and see if there is one in the A/H. Look on the right end (return end) There is a panel anout 1" wide going from top to battom. There may be a filter left in there.
Nov 13, 2009 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
