Question about Jenn-Air Microwave Ovens
Jenn-air microwave (Model JMV9169BAP) inside light burned out. Can't see how to access bulb to replace it.
SOURCE:
Master_Tech
  • 770 Answers
SOURCE: LIght bulb burned out
i will call you Yes it is a Pain to replace it
Posted on Jan 24, 2008
MicrowaveSvc
  • 9174 Answers
SOURCE: jenn air microwave oven door handle
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
SOURCE: bulb replacement
I realize this is late but for other's here it is:
If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb.
Posted on Sep 09, 2008
MicrowaveSvc
  • 9174 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9174 Answers
SOURCE: Changing light bulb in microwave oven
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Posted on Oct 20, 2008
Hello, i'm looking to replace my light bulb in my jenn-air microwave oven modeljmc8130dds. any help would be greatly appreciated.
The lamp is inside the oven so it is necessary to remove the cabinet but be aware that dangerous voltages are exposed even with power disconnected.
Oct 22, 2016 | Jenn-Air Microwave Ovens
Tip
How do I replace light bulb on my Jenn-Air microwave?
Hi.
You will need to partly disassemble the oven by removing the outer cover held by screws (the cover part 2 on the first diagram). once there you will see the bulb hand side, located on the right (the bulb is part 6 in second diagram).
Before disassemblying the appliance disconnect power, by tripping circuit breaker or unplugging the power cord.
Here the replacement part for the model JMC9158AAS, listed in title: PS391758 .
Diagrams below are also for Jenn-Air JMC9158AAS.
If you have a different model, use the links listed here: Where do I find parts and diagrams for my appliance?
Here the diagrams. Click on the pictures to enlarge.
Diagram 1:
Diagram 2:
Unless you are a technician or a trained DIYer, better ringing the number listed on the owners manual to call service support. A badly assembled microwave will be dangerous for your health. The capacitor inside the microwave can also release dangerous discharge, take care and observe safety prescriptions while disassembling.
Regards.
on Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
Changing the lamp in microwave of GE model pt970srss
If it is at all like a plain microwave oven, you will have to remove the screw for the cover to access the insides and likely will find that the light is not a simple screw-in bulb but a sealed package with a spare of spade terminals on top. It may be held in by one or more screws.
It is possible that this could be like a new conventional oven where you have to remove a light cover inside the cavity to access the bulb and change it
May 13, 2014 | GE Profile PT970 30" Built-In Double...
I have the Jenn-Air microwave oven. It is mounted in a cabinet. How do I replace the light? Should I try to remove the microwave from the cabinet? If so, how is this done. The manual is vague on this. It...
Most microwaves are similar in design, and here is how for a GE, which will most likely apply to the Jenn Air:
http://forum.appliancepartspros.com/microwave-repair/84864-microwave-lightbulb-replacement.html
This site explains the process:
http://forum.appliancepartspros.com/microwave-repair/165-microwave-interior-light-bulb-replacement.html
To discharge the cap, you can touch an insulated screwdriver across it's terminals, but just avoid the contacts and you will be fine.
Sorry to have to relay tough news, but how this helps you repair it.
Sep 10, 2010 | Jenn-Air Microwave Ovens
Inside Light DOesn't work
You can try repairclinic.com. Just enter the model number of your oven and it should list the part number as 1068482 with the price as $10.45 plus shipping.
Jul 01, 2010 | Jenn-Air JMV8208BAS Microwave Oven
HOw do i replace the inside bulb?
Hi. I just told you, there is no acces for the bulb in microwaves. Bulb replacement is not supposed to be a user level maintenance operation. You will need to remove the microwave outer cover to replace the bulb.
Here again my instructions: How do I replace light bulb.
Regards.
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find handy exploded views and order parts by model number here.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Broken light bulb
Go to an appliance parts store to get the bulb.
Good Luck and Please rate fixya!
Feb 23, 2009 | Jenn-Air JMV8208A Microwave Oven
Sharp model r-5a56 light bulb is not on.
take off the back panel and replace the bulb
Jan 02, 2009 | Jenn-Air JMC8130DD Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail [email protected]
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
297 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
