Question about RCA Televison & Video
Rca tv will beep three times but wont turn on
  • RCA Master
  • 5,138 Answers
You need to Post your Model#
Posted on Oct 23, 2010
SOURCE:
I turned on my tv this morning and the power light is flashing and tv wont turn on
if the power indicator flashes three times then goes out and stays out then its usually the power caps which are CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the repair instructions on CD
Aug 08, 2011 | RCA R52WH76 Television
I have a rca rear projection tv model number d52w17 and when i turn it on it beeps three times and after it beeps three times nothing else happenes. i have un plugged it and waited for 30 min like a friend...
You have a capacitor that has gone bad on the HV power supply board on the left side, the number is cp150.It sits behind an aluminum heat sink in the middle towards the front, it will probably be bulged at the top. Along with that since the board will be tilted up I would re- older all the connections on the HV transformer, that's the critter with the red lead coming out of it. Your done!
Dec 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 WONT TURN ON...GREEN LED ON /OFF THREE TIMES
LOCATION NUMBER CP114,CP150,CP140,CP120,CP130 ANY CAN BE BAD ALSO SOLDER LOOSE CONNECTION UNDER FLYBACK
Aug 28, 2009 | RCA HD52W58 52" TV
Will not start properly RCA D52W17
There is a cap behind a heatsink on the Deflection board I believe it is CP150 or 180 which is a 2200uf/35v
Feb 09, 2009 | RCA Televison & Video
RCA 32 in TV no picture no sound just a beeping noise TV power is on
HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
Jul 20, 2008 | RCA 20F511T TV
I have an rca model # p46802bl projection tv it wont turn on and it makes a beeping sound in the back can you tell me what to do
Good Day,
First of all unplug your TV from the wall for at least 5 minutes (re-boot).
The RCA has a protection circuit it will not allow TV to turn on if it detects a short. It will attempt to turn on 3 times. There is not a common problem with this unit.
Call an authorized service company if the above did not correct your concerns.
Good Luck. God Bless. bi
Jun 10, 2008 | RCA Televison & Video
Tv wont turn on
my tv wont turn on and i dont have no sound or no picture it flask on and off
Feb 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
T.V. dead
Sounds like something has shorted out, the "three beeps" are they loud or softer, high pitched or low, would suspect that you might want to call someone out on this as it could be a number of things.
Feb 15, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
