Question about Standard Horizon Cp180 Chartplotter
Hello, I was told that my CP180 is broken because of corrosion. Do you know of another reason why the GPS will not turn on?
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
Hello, Can you tell me what make of GPS will work with the Icom m-504. I tried using the Garmin 76csx with the NEMA in/Nema out function set, but it will not communicate to the Icom. I would appreciate...
Hi!
We had the same problem with our Uniden Oceanus failing to communicate with our GPS. What the problem was, was that our VHF didn't recognize the NMEA sentences transmitted from our "ancient" GPS. We ended up buying a Standard Horizon cp180 chartplotter. PRESTO! Our DSC capability materialized.
Your 76CSx is newer than our Magellan was, so before you take on the task of a $400 chartplotter purchase, just make sure your BAUD rate is set to 4800. This adjustment alone could make your GPS work with your ICOM.
Hope this is helpful.
Jan 23, 2011 | Icom IC M504 Black Submersible PLUS Marine...
Can it take ais?
A Standard-Horizon CP180 Chartplotter can recieve information from an external AIS device with a NMEA data wire connection. The cable from the NMEA output of the AIS would be connected to "Port 1" (Page 18 of the CP180 user manual) on the CP180 and then the CP180 menu settings configured to show AIS targets, data, etc. (Page 21 on the CP180 user manual)
Nov 19, 2010 | Standard Horizon Cp180 Chartplotter
No gps signal on my tomtom one
the antenna is the cause if the gps is not having signal or reception.
Check the antenna is broken or well fixed. If not, you will have to replace the antenna.
Take care.
Jul 21, 2010 | Tomtom ONE XL GPS
Dont want to turn on
IF the internal battery is dead, which happens, it will no turn on even with good batteries or the DC plug. Lots of info online on how to replace it, make sure you use the correct type.
Apr 05, 2009 | Garmin GPS III Plus GPS Receiver
I am trying to delete all tracks/routes on CP180 Standard Horizon
reading your owners manual (link provided at below) , i see you can delete / edit points one at a time or a faster way format the C Card.
** formatting the c card instructions >
1.) press MENU , move the shuttle point knob to highlight USER POINTS , and press ENT .
2.) move the shuttle point knob to highlight USER C CARD, and press ENT .
3.) move the shuttle point knob to highlight FORMAT ,
and press ENT .
4.) a popup warning window will pop up to confirm you want to format the user C card .
5.) select YES , and press ENT to confirm , (select NO otherwise) .
NOTE : formatting the user c card erases all files previously saved on the c card .
CP180 users guide
J5
Jan 17, 2009 | Standard Horizon Chart Plotter CP180 GPS...
GPS MIO C220 Screen not responding
Hello Carlos,
The touch screen is broken. You can find the replacement part here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390
You will have to provide the part number at the back of the screen.
Saludos,
Apr 13, 2008 | RIM BlackBerry Pearl 8100
Question
I have the same problem.... Please let me know if you find a solution.
[email protected]
Dec 27, 2007 | Garmin StreetPilot C330 GPS Receiver
NVX226 Navigation System
My Gps mountain kits is broken I want to know where can I buy it
Nov 28, 2007 | Audiovox NVX226 GPS Receiver
Standard Horizon Cp180 Chartplotter Logo
Top Standard Horizon Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
