Question about Toshiba TZ43V61 43" Rear Projection Television
My tv is not turning on. we just moved from one house to another did the move disturb it
    New Friend:
You need to take the front panal off to look and see if all three sockets on ctr tubes are seated all the way. the front panal is the one with the power button,vol and ch buttons and aud/vid hook up. first remove the shiny screws from the back on the sides of tv where speaker grils are. remove the speaker grills. then you have four black screws two on each side of panal and two shiney ones on top of panal. remove all six then remove panal careful not to pull too hard on wires. then making sure tv is unpluged, reach in and under the three tube assembelys, push up under the circut boards right center of where the scoket connects to the tube and make sure they are seated all the way. doesnt take much pressure to push on them so dont kill them. also be careful not to do it off center of the board or board or worse the tube will break. if all is well there, you will have to remove more panals and look a little farther for somthing lose or broken. good luck.
Posted on Nov 08, 2010
SOURCE:
Problems with my Samsung s7
Check the settings for the vibrate mode.
Have you put the phone on 'Silent'?
Go into Settings,
Go to Sounds and Vibrations.
Turn 'Sound mode' to Sound.
Turn 'Vibrate while ringing' to on. (Move the dot right).
Turn 'Vibration intensity' to a higher setting, (Move the dot right).
Scroll down to 'Do not disturb'. Turn off. (Slide the dot left).
Oct 11, 2018 | Cars & Trucks
I have the Yamaha HTR-5940 and it has worked fine for years. Today turned on and there is no sound for the TV. Sound works fine for DVD, and radio. I have tried everything except toss it out the window....
did you connect the cables correctly most probably to get sounds out of a tv it should connected to the 3.5mm headphone jack.
you would need a Rca to 3.5mm cable for this
Oct 20, 2017 | Yamaha HTR-5940 Receiver
Wave like disturbance in monitor after moving
change your refresh rate on the monitor, plug it into a ups to regulate the power. may have emi interference coming from other sources
Aug 06, 2009 | iiyama Computers & Internet
I just bought a sony triniton 40in trusurround
7 Blinks is the code for high voltage shut down and can be due to a failure in the horizontal deflection circuit.
Since it worked before it was moved, i would guess that you may have disturbed a bad solder connection or possibly cracked a PC board.
IF you feel comfortable doing so you can give a visual inspection of the board
With the power off and TV unplugged remove the back cabinet. Slide out the board and flip it over to check for poor solder connections/cracks in the traces.
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Old GE 13 inch TV TX826TB 13GP243 does not respond consistently when I try to turn the power on. My neighbors just moved and had no spot for it in the car. They watched it all day the day they moved. I...
Doesn't Tried another outlet and it turned on suggest the problem is with the outlet?
Are you talking about a power or a TV signal outlet, please?
Nov 29, 2017 | GE 13GP243 TV
Lcd tv with in built dvd/cd. can't read disc keeps ejecting it
run a cleaning disk through the system -- then try again --- sounds like the unit wont read the disk properly and by moving it -- some dirt or dust may have caused this problem
Feb 19, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
PS3 powers up but no display on tv
Try holding the power button down for about 30 seconds to reset to factory settings
Jan 23, 2009 | Sony Playstation 3 (PS3) Console
Power on samsung plasma tv
Where did you move from and to?
Mar 07, 2008 | Televison & Video
Toshiba TZ43V61 43" Rear Projection Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
