Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Both the refrigerator and freezer compartments do not get cold.
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
  • 87 Answers
SOURCE: refrigerator doesnt get cold enough
If you remove the back panel on the inside of the cabinet then you would be able to check the evaporator coil (cold bit) and see if it is frozen up. If it is then defrost the system and see if you have any improvement. All the things you have pointed out over the compressor is normal, they do run incredibly hot. If you have got the freezer on a very cold setting I would suggest bringing both setpoints to a mid range setting. Check the temp in the fridge by measuring liquid temp as air temp is prone to fluctuate more. If you still have a concern I would suggest contacting a fridge guy to assist you. Hope this is of some if not limited help.
Posted on Sep 11, 2007
  • 21 Answers
SOURCE: Freezer quits working
Good Day, I live out in Ca. and have only experience temp's like what you guys endure once in my lifetime. But I grew up, with Bart Starr, he was my guy, leading the Pac. in the Ice Bowl. I'm hoping to get one of the guys to add to my comments I'm going to suggest to you, there are many guys more qualified with more experience than I, that might offer more. Sometimes with Refrigerators and Freezers, is that during periods of long cold spells, the appliances can actually NOT produce enough Run-time to sustain the foods inside. In other words, because its so damn cold it will go off and if the thermostat doesn't sense the temp has risen to the point it needs to come back on, it won't. Ice creams, because of the salt content, bread (it has no density) these will be the first foods to be effected. 20yrs ago I remember we have a strip heater... wr49x211 I think it was, to add heat to get the thermostat to cycle back on.... Check around, ask -Re-post and List it.. I want somebody who knows Refer's, Lives and Works in tough weather... that'll get an answer
Posted on Feb 27, 2008
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
What could the problem be; my refrigerator not cold but the freezer is freezing?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail with illustrations how to dx and fix: Refrigerator Defrost Parts
Jul 31, 2014 | Emerson Cr500 Refrigerators & Freezers
Drain water freezes in the back of the freezer compartment and no cold air gets to the bottom compartment.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Whirlpool ET1MHKXM Top Freezer...
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Mod ED27DQ side by side refrigerator-Freezer works fine-refrigerator will not cool below 45 degrees
check the damper door located between the freezer and refrigerator compartment,if it is iced up it cannot open up and let cold air into refrigerator compartment from the freezer compartment,deice this part and then adjust the refrigerators cold control and see that the door opens and closes with controls adjustment
Jan 31, 2010 | Whirlpool Refrigerators
The freezer is cold but the refrigerator section is not getting cold...it is not warm but not cold according to the dial settings
check the operation of the damper door between the freezer/refrigerator section which lets cold from freezer into refrige compartment for ice build-up which will cause damper door to not open fully and cool the refrige compartment,if this is the problem,unplug the door ans remove and let thaw then replace and try it then
Jan 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
The top of the freezer part is getting cold but the bottom of the Refrigerator part is not getting cold. The Refrigerator is only 10-11 months old ; what is wrong?
you need to check and see if the fan in the back of the freezer compartment is running. when the fan is not running the cold air will not be passed to the refrigerator compartment. open the freezer door and turn the unit to its coldest setting until the compressor kicks in then listen to hear the fan in the freezer compartment.
Sep 16, 2009 | Refrigerators
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
The fridge is not working although the freezer is fine. the fridge temp is showing 24 and i cant change it
Feel with your hand for the spot where you feel the cold air entering into the refrigerator compartment.
Look for something near the area that says more/less cold. Sounds like the air flow is stuck open allowing too much air from the freezer compartment entering into the refrigerator compartment. A refrigerator works off the basics of recieving cold air from the freezer compartment.
Nov 06, 2008 | Refrigerators
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
35 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
