Question about Dynex Computers & Internet
My wireless will not work and all the lights were flashing now they are solid green and i dont even have the ethernet cable plugged in. what should i do to see if i have a bad router.
  • Dynex Master
  • 7,733 Answers
SOURCE:
Other lights blinking but internet light is blinking for 2-3 times them off all the time so I am not getting internet
On most DSL modems, normal light states are:
Power - Solid
DSL - Solid
Internet - Solid or flashing quickly when data is being transferred.
Ethernet - Only on and flashing quickly if cable attached to it and an active device
Wifi - Solid or flashing with active data transfer
Sep 24, 2014 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:
check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.
May be it can be cause of Incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
***If you need any kind of technical assistance you can contact support cell at here
Feb 01, 2013 | Actiontec GT704WG Wireless Router...
Just got a qwest pk5000z when plugged in power light stays solid green, dsl light stays solid green, then I receive Internet connection.. After about 30 seconds it resets and starts the whole process over....
Are you using the RJ45 ended Ethernet cable?
I've been battling an issue where an Ethernet cable plugged in caused the PK5000Z to reboot approximately every 120-300 seconds (2-5 minutes).
Switching to just the wireless and not having any Ethernet cables plugged in resolved the issue.
Unfortunately this won't work for me since I only use the modem as my gateway to the internet and actually have an Astaro Secure Gateway Firewall that connect to the modem via Ethernet. I'll be contacting their technical support again tomorrow as I've had 3 modems RMA'd and not a single person there at Century Link could figure out what to try except to keep RMAing them.
So anyone else hitting this issue, try using just the wireless instead of the Ethernet Cable.
Jan 24, 2012 | Computers & Internet
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
I unplugged my router (used as a wireless repeater) to plug it into a surge protector and it will not reset manually. The blue light on the top is on solid (not flashing like before) and the numbers 1-4...
A client of mine had a similar problem. Apparently she had accidentally plugged her modem's power cable into the back of the router and the power cable for the router into the modem. Worked like a charm once the cords were switched.
Aug 04, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Xbox 360 Does not recongize my wireless adapter
My adapter light is a solid red. When I plug in an ethernet cord, that'll connect.. but when I take the ethernet cable out, the 360 always reports Disconnected under Network Adapter even though the wireless adapter is plugged in.
Apr 03, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless connection problem
Hello:
Ok...I am a bit confused. You must have a modem to connect to the internet...whether you are broadband (cable/DSL/wireless), Dial-up or T-1 or higher (TSU/DSU).
This is how it should run once you are sure you have the modem...
Modem....to router...pc to router. If you have no router...then plug ethernet cable from your modem to your NIC card on PC.
You will have to make sure your network card is working (check for flashing green light and one solid green. Then you can goto COntrol panel and run the wizard to connect to the internet...it should work.
What kind of router do you have? Also, what is the model number of your modem?
Let me know if I can help further.
Good luck my friend.
SeekPCRepair
Feb 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
62 people viewed this question
Top Dynex Computers & Internet Experts
gggg
Prashant M
Prashant M
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
