Question about LG 42LP1D 42 in. LCD HDTV
TV fault I have had my 42" TV for just under 2 years and iv already got a bad fault with it. it turns on and just as the screens about to come on it goes back to standby and attempts to start up again. This is a constant loop. I hope someone can tell me please whats wrong :o(
  • talk2medoc Apr 19, 2009
    Same thing, 2-year-old LG 42-inch LCD suddenly stopped working after being perfectly fine. Will turn on with lots of pushing buttons but only stays on 4-5 minutes then an error messages flashes on screen, something like "___ data instructions." It goes off so quickly I cannot read the first word.
Main motherboard faulty or needs new software
Posted on Sep 28, 2008
Panasonic VIERA TC-L42U5 42-Inch 1080p 60Hz Full HD LCD TV (Screen doesn't work)
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2017 | Panasonic Televison & Video
My 47LG70 tv went out. I heard a pop and the screen went blank. The lower right hand sensor light turned blue. I tried unplugging but that didn't work. When I tried to turn it on again the sensor light...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 02, 2017 | LG 47LG70 42 in. LCD TV
Random 3'' vertical red line on 42'' Hitachi Plasma TV
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Screen only partial and only shows in red and black
sir/mam the problem of your plasma t.v is the panel,weak panel. i have already encountered that kind of problem.
Aug 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Sony Bravia 42" Horizontal Lines
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 19, 2017 | Sony Bravia KDL-42V4100 42 in. LCD TV
2" wide Red stripe on right side of LG 42" plasma TV screen
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Jun 09, 2017 | LG DU-42PY10 42 in. Plasma HDTV
42 inch screen
Did you measure diagonally from corner to corner? This is usually how all manufacturers quote screen size. Hope this helps
Dec 07, 2008 | Polaroid FLM-4201 42 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Screen issues :(
Sounds like the Y-Buffer board, not the housekeeper sadly...
Most common part that goes bad...
Dell will charge you $1200 or so to just look at it...
Mine was 3 days out of warrenty.. Dell told me to go pound salt..
If you can find someone to look at it... Here's the part number that might be bad...
http://www.partstore.com/
Phone Number: 1-866-925-7278
PCB: LJ41-02760A - $84.36
And yes... Dell 42", Sanyo 42", Phillips 42" , and Samsung 42" Plasma's all use the same parts.
Jul 28, 2008 | Dell W4200 42 in. HD-Ready Plasma...
42" LG plasma
It sounds like a bad panel, which is not what you want to hear. Replacing the panel on a Plasma TV usually costs more than just replacing the TV. However a bad panel causes vertical lines exactly as you describe.
Sep 10, 2007 | Sony PFM-42X1 Plasma TV
LG 42LP1D 42 in. LCD HDTV Logo
244 people viewed this question
