Question about Dryers
GE DBXR453 Electric dryer suddenly will only get warm so clothes take longer to dry. This is what I have done: 1. Checked that correct 220 voltage is going to socket. 2. Cleaned out lint build up in complete exhaust path from outside vent through dyer to the blower fan. 3. Checked the rear heating coil, thermostat, thermostat center inlet, safety thermostat, and thermostat bias drum out for continuity. Everything checks out fine. What could it be?
  • 2 more comments
  • arzee1 Oct 23, 2010
    Where is it located?
    I don't see a sensor connected to any part of the air vent running from the front of the dryer to the rear. However, there is a sensor connected to the housing around the blower fan which connects to the air vent. This is a "thermostat drum out" according to the parts list. Is this the part I should replace?
    There are only three thermostats, which one can it be?
    safety thermostat
    So should I replace the "thermostat drum out"?
    Top Expert:
  • Dryers Master
  • 85,206 Answers
A defective mositure sensor.
Posted on Oct 23, 2010
  • 2 more comments
  • Marvin
    Marvin Oct 23, 2010
    in the air vent
  • Marvin
    Marvin Oct 23, 2010
    This can be caused by the Cycling thermostat,
    Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
  • Marvin
    Marvin Oct 23, 2010
    not all have the moisture sensor, so u have a cycling T-stat issue then
  • Marvin
    Marvin Oct 23, 2010
    contact this web site they have live chat free and can supply the terminology for the cycling T-stat that GE uses for it www.repairclinic.com
SOURCE:
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
I have an unusual problem with my GE dryer. I just moved in and noticed it was taking a longer time to dry my clothes than it normally did in my previous home. I checked to make sure it was getting 220...
here is the way it is wired on the back of the dryer:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
outlet should correspond the same, Hope it helped Tim
Apr 20, 2011 | Bosch Nexxt WTMC3321US Electric Dryer
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
My GE dryer DBXR463 electric dryer doesn't dry the clothes all the way anymore? What could be the problem? I have cleaned all of the lint and checked the venting on the back. It used to worked fine for...
Check the entire vent (exhaust ) system start the dryer and go outside to the exhaust vent ,you should feel a good amount of warm airflow.bet you will fine low airflow. You need good air circulation to help remove the moisture from the clothing warm or hot temps alone would take longer if ever to dry ..this generally happens slowly over time and the next thing you realize is that its running much longer than it use to... plus it cost more....if you still have a concern you may have a thermostat that is short cycling not letting it get hot enough long enough... Hope this helps GOOD LUCK
Aug 21, 2010 | GE DBXR463EBWW Electric Dryer
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Condensor tumble dryer not drying clothes
Give the correct model number in full. It will be near the serial number. Engineers plan projects and drive trains!
May 25, 2009 | Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
