Question about Dell OptiPlex GX270 PC Desktop
Unable to power on a dell gx270. swapped ps with another. same problem. tested ps, ok. what gives?
    New Friend:
  • 71 Answers
Try jump starting it by shorting the power switch pins on the MB with a flat head screwdriver. If it starts then check the power switch on the case for loose connection. If it fails then replace the MB.
Posted on Nov 17, 2010
SOURCE:
Navana Fault POWER MODULE TIME OUT. Cannot start machine
yes. when one of the phase is out, the other two power module is usually overloaded and burnt. swap it.
May 19, 2014 | Ingersoll Air Tools & Compressors
I have used four different Dell Optiplex GX270 pc's, each time the video card burns out and I am unable to recover my data. This more than frustrates me as I work in a church and have sensitive...
there is a known issue with the dell optiplex 270's. if you open the case and see the top of the capacitors are not perfectly flat then you have an issue. I would go ahead and upgrade and invest in a good backup solution.
Jan 05, 2011 | Dell OptiPlex™ GX270 PC Desktop
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
I have a Dell GX270 and i replaced the P4 2.4 Processor with a P4 2.8 and now all i get when i turn it on is a sollid amber light on the power switch, Nothing else. Does not boot. Can you tell me what is...
Its possible the motherboard does not support the new processor. its possible there might be a firmware update for the motherboard to add support, otherwise you might be out of luck.
Swap processors back, confirm that it works again, and if possible confirm that the new P4 is in fact working.
Apr 07, 2010 | Dell OptiPlex GX270 PC Desktop
Switching hard drives
Yes but with one stipulation. If they each have different hardware (like video cards for example) the drivers may have to be reinstalled if it is windows that is on these machines.
Mar 20, 2010 | Dell OptiPlex GX270 PC Desktop
WANT TO INSTALL THE PC SUITE ON MY COMPUTER USING CD BUT IT GIVES AN ERROR OF NON EXISTANCE OF NPS
there may scrach in the cd so computer gives error try another cd or try cd on another computer if cd id is ok then that is problem of virus format the pc and reinstall the operating system
Mar 13, 2010 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Proper pin numbers to install inserts in a Dell SATA 34 pin GX270 motherboard
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so take a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
334 people viewed this question
Ekse
Clive
Clive
