Question about Eureka Vacuums
Help hi i have a eureka bravo model #9270 and i need instructions how to change the belt, i took out twoscrews it looks like the top comes off but it doesn't come off all the way.
  • 77 Answers
The handle should be down and the top may have a tab on both sides to pry out with screwdriver. lay handle down and turn machine over. look closely around base between cover and there should be a tab to push on and cover comes off.
Posted on Jun 12, 2008
How do you replace the belt on the Eureka 4495A Upright?
hi there,
on this model there are 2 screws on the top of the unit just above the brush as you are looking at it.
Remove the 2 screws there and the top cover should come off.
There is also a black and yellow sticker under the top cover near the belt that describes in detail on how to change the belt there. Once that is done line up the cover and put the screws back in.
Good luck .
Nov 19, 2010 | Eureka 4495A Bagless Upright Vacuum
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
I have a eureka bravo upright model 9600. I have removed the hood . I need to remove the brushe roller to install a new belt. I cannot figure out how to remove the brush roller.
Check out this URL:
http://www.svcvacuum.com/beltrep2.html
looks like it has just what you are looking for. Would appreciate a thumbs up on this if you find it beneficial. Paul
Oct 04, 2010 | Eureka Vacuums
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
How do you change the belt on a model 5856
here is a link to the manual which has instructions and to the belts you need
Eureka 5856 Belts
Eureka 5856 Owner's Guide
Nov 22, 2009 | Vacuums
CHANDE BELT
you can find out how to change the belt in the manual here that I included on page 4.
http://www.eureka.com/servlet/FindOwnersGuide
Good Luck And Please Rate FixYa!
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing belt - Eureka Whirlwind 5740
I tried the website for manuals but no luck. I called the toll-free # 1-800-282-2886 and got a rep right away. I gave him the model and s/n (lower bottom on the back side) and he walked me thru it. For the model I have, there are 3 screws to remove - With the vacuum upright and standing facing it - there is on on the right and one on the left of the bottom cover and one on the left side near the hose intake. Remove those to get to the belt. I ordered the belt with him too - althought the belts were cheap ($2.99 for 2) the shipping was $8. If this didnt help - call the 800# - they were great.
Dec 08, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Mar 01, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Vacuums Logo
74 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
