Question about Mossberg Rock & Ice Climbing
46 A 22 bolt will not eject the spent cartrage what's wrong and how can this be fixed? Also where can I get parts? And not sure the safty is working
  • 11,800 Answers
The hook on the bolt is either out of position because the spring holding it has failed or the hook itself is damaged. Remove the bolt and fix it securely in a vice; press the fixing pin while securing the hook of the extractor in place - once the pin is out the hook should pop out. Fit in reverse the new parts. if you don't have the required experience you should better leave that to a gunsmith.
You can buy parts from here
http://www.havlinsales.com/22rifle.htm
Posted on Oct 23, 2010
SOURCE:
Mossberg 817 magazine
Not much can go wrong. Have you checked your extractor? If it's intact and not broken, try moving it with your thumbnail. Is it loose? That's a spring problem. If it's tight and intact, WITH THE BOLT OUT, try slipping a small diam wooden dowel down the barrel to see how hard it is to push a spent shell out. If it's tight, you've got a burr in the chamber or dirt/varnish buildup. Examine the shell for scratches. If the shell's good and no scratches, clean the chamber with a brass brush mounted in a drill.
Apr 21, 2014 | Mossberg Optics
Extractor claw does not hold the ammo
It sounds like it's not seated in the bolt properly or the lip is broken off. (I've not seen a broken 98-type extractor in 50 years.) Pictures?
Mar 19, 2014 | Cz Usa CZ 04101 CZ550 AMERICAN 6.5X55
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
Why does my printer not print
Ink cartrage could be installed inproperly..the machine Must be close and latched properly also. p.s. Make sure the safty tab is removed from the new cartrage.
Jun 07, 2012 | Brother MFC-3360C All-In-One InkJet...
Can't get the shifter out of park position please help
ok check brake light bulbs first i spent 100.00 tring to fix mine come find out its a safty feature of some kind
Oct 07, 2009 | 2004 Lincoln Aviator
Model 70 270 win will not eject spent shells where can i find parts for winchester model 70 xtr 270 win bolt
Try Numrich---they have just aout everything. You can find them on their web site
Sep 22, 2009 | Sport & Outdoor - Others
Turn key nothing happens all lights work fine,is there an ignition safty somewhere?it's a 1994 s10 blazer
have it checked at a auto parts store for any faults but im sure replacing the starter could fix maybe fix it
Mar 06, 2009 | 1994 Chevrolet S-10 Blazer
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Rock & Ice Climbing Logo
65 people viewed this question
Top Mossberg Rock & Ice Climbing Experts
ray gallant
ray gallant
Philip Hughes
Are you a Mossberg Rock and Ice Climbing Expert? Answer questions, earn points and help others
