Question about Tappan TGFS_63 Gas Kitchen Range
I can set my oven but it shuts off - Tappan TGFS_63 Gas Kitchen Range
  • 1,531 Answers
You need to check the ignitor ans see if it is working correctly.if this is malfuncting then it needs to be replaced it may not be drawing enough current to open the gas valve.
Posted on Oct 23, 2010
SOURCE:
I have a GE wall oven JGRS14GEVIBB and the problem is that it heats up to the set degree level and then totally shuts down.
There could be a bad connection on the electronic control. Try pulling the connectors off and reinserting them. There may be a thermal breaker in the top but it shouldn't shut down the oven unless it is giong bad.
Nov 24, 2014 | Ovens
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Oven lights and works fine till it reaches set temp then panel goes blank and oven shuts off
Check the cooling fan inside of your control panel. Most likely the computer board overheats and shuts itself down.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 25, 2011 | GE JGRS14 Gas Single Oven
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Oven gets too hot, beyond what the thermostat is set.
Here is a tip that will help you figure out why your oven will not shut off...
Electric Oven Problem Oven will not shut off
heatman101
Dec 26, 2010 | Jenn-Air Electric Double Oven
Oven starts then flickers and shuts off
HI, this is a damaged control board here. replacing the control will fix this issue. the chip set is faulty.
Jun 17, 2009 | Microwave Ovens
Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 29, 2008 | Magic Chef 9512 Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Tappan TGFS_63 Gas Kitchen Range Logo
50 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
MARLON KELLER
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
