Question about Microwave Ovens
Need operating manual for Cook's stand mixer Model SM248, 700 watt, 12 speed, 5 qt
2 Suggested Answers
SOURCE:
  • 8909 Answers
SOURCE: cooks commercial stand mixer model
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 29, 2011
Need manual for Hamiltion Beach 1000 Watt microwave, model # HB-P100N30AL-S3
How do you use the power button. Like if you need to cook something at 50%?
Sep 17, 2012 | Microwave Ovens
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Watts divided by volts = Amps
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Cooks commercial stand mixer model SM248 700 watt, i need an owners manual
I hope this helps.
Mar 29, 2011 | Microwave Ovens
WMH 1162X VS -1 (watts unknown) Builder purchased
If the oven is set up to vent outside, then the metal mesh grease filters are used, and they should be cleaned in warm soapy water whenever they look greasy or dirty.
If the oven is set up to recirculate, then the charcoal filter is used, and it must be replaced (not cleaned) every 6-12 months, depending on use.
This model does not have a separate cooling fan like most other models. It replies on the vent fan for magnetron cooling, so if the filter(s) gets too dirty, it can reduce the cooling air flow, which can allow the magnetron to overheat and be destroyed.
I would need to know a little more to help narrow down the "no heat" problem.
If the cooling fan, turntable, and inside light all come on when you press "Start" to cook, then I would ask if you here a "thump" when you press "Start."
If so, then the high voltage section is getting energized. If not, then it may be the cook relay on the control board, which I can affordably repair.
The support page for your oven is here, and it has manuals and part lists you can download.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | Whirlpool WMH1162XV Microwave Oven
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
Power level again
It is probably a 700 watt model. Most ovens have 10 power levels, ranging from 10% to 100%. Normally you press POWER LEVEL, then press 1 for 10%, 2 for 20%, etc., then press START or COOK to cook. We could not find exact information on this model.
Mar 25, 2007 | Samsung MW4350W Microwave Oven
Microwave Ovens Logo
436 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
