Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
I have Hoover Floormate Model H3004. The machine will no longer dispense the cleaning fluid due to the trigger assembly not engaging properly with the inlet/outlet on the Clean Water Solution Tank. I have checked and made sure the tank was seated properly.
SOURCE:
  • 8 Answers
SOURCE: Hoover FloorMATE 3000 won't dispense cleaning solution.
I had the same problem with my Hoover Floormate H3000 and found the solution elsewhere on this website. Try doing a search for Hoover Floormate H3000. The posted solution is basically as follows:
Remove the liquid dispenser tank and set it aside. Look into the cavity of the machine where the tank attaches and find the plastic "plunger" piece (the one on my machine is a blue/grey color) that is surrounded by a black rubber circle. Put a small drop of hot glue on the tip of this plastic "plunger" piece and let it harden. Replace the liquid dispenser tank and try the machine again. My machine dispensed liquid properly after this fix-it.
I really appreciate the poster who provided this simple solution!
Posted on Aug 29, 2008
SOURCE: Hoover Floormate SpinScrub won't dispense cleaning liquid
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
Posted on Feb 07, 2009
  • 13 Answers
SOURCE: my hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
Posted on May 25, 2010
  • 13 Answers
SOURCE: hoover floormate h3000 not dispensing cleaning
check the seat valve on the bottom of the solution tank. should move upward freely. could be stuck if sitting for long period of time
Posted on May 26, 2010
  • 3 Answers
SOURCE: hoover floormate h3000 w/spinbrush will
The hot glue trick will work; but what you probably need to do is gently push down on the black pin from inside the tank. This will lower the solution release mechanism and the solution will dispense. I found this solution on this website and it took 10 seconds and worked well.
Posted on May 01, 2011
New hoover floormate deluxe does not seem to be cleaning tile floor
Take it to your local Hoover warranty station. You have a one year warranty. These new machines are giving some trouble.
Feb 19, 2015 | Hoover FloorMate Deluxe Hard Floor Cleaner
My floormate spin scrub solution dispenser button is difficult to push and when I do push it I can not see the plunger rod moving to raise the solution tank plug. How do I fix this?
Hi Melissa, this is one of our older designs that we recommend you take to a service center to get checked out. Find one here: http://hoover.com/locator/. We do listen very carefully to feedback like yours and implement that in our newer models. If you are looking for an upgrade, take a look at our FloorMate Deluxe: http://bit.ly/1sLrS5x. Hope this helps!
Dec 20, 2014 | Hoover H3040 FloorMate SpinScrub Widepath...
Hoover floormate will not dispense solution
this is the original Hoover Floormate, and may have a few different things that may be wrong. First check the fresh water tank is seated or installed properly. Second, it may be the pin on the actual unit itself that is not pushing in the plunger (located on the water tank) all the way to release the solution. Check for clogs above the brush block assembly the small holes may be plugged with dried sop solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 29, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
How to fix clog on hoover floormate fh40010?
I was having the same issue with my NEW just out of box Hoover FH40010. First run on the floor was great then the water/cleaner stopped dispensing!!! I found that when is assembled it out of the box I did not have the handle "plugged-in" properly!! I reattached it to where there is NO gap in the handle when pushed firmly into place and locked in the base. WATER SOLUTION NOW WORKS PERFECTLY!!!
Nov 30, 2012 | Hoover FloorMate Hard Floor Cleaner -...
Floormate does not disperse wet cleaning solution on the floor. brushes and vacuum pickup all work
First check to see that the wheel assembly is not broken. The assembly must move correctly to allow the fluid to be dispensed. Check for breakage at the rear of the wheel assembly where it attaches to the base. If this is not the problem, you may have a defective soap tank.
Jan 22, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover spinscrub water keeps coming our
Check the machine where the water tank is installed, you will see a pipe stem this stem should have an o-ring gasket on it. also look at the plunger in the tank for proper seating.
Jan 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Won't dispense cleaning solution
I had this same problem. There is a solution posted elsewhere on this website. Search for Hoover Floormate H3000.
The following solution is the one I tried: Remove the fluid dispensing tank and put a small dab of hot glue on the tip of the blue/greyish "plunger" piece that is located in the middle of the black rubber circle. Let the hot glue dry (this forms an extension to the plunger piece...) and replace the fluid tank.
I did this and my machine is working properly again! Whoever posted this solution was very helpful!
Aug 24, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Feb 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Nov 19, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
91 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
