Question about HP L1906 19" LCD Monitor
HP L1906 picture does not re-appear immediatly, after being away from it for a while. The green light flashes for about 2 min before the screen re-appears.
  • 11,361 Answers
It may have dying power supply due to bad DC filter caps just like the HP as shown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 24, 2010
SOURCE:
1) when i switch on my hp L1906 19" LCD monitor display comes for 2 sec. or 3 second then it goes blank. then i have to switch off and again switch on but problem remain like that... 2) in my second...
this question is posted here 100 times, search much.
the CCFL tubes are burned out
as all do ,every 20,000 hours, 5 years old if run 10yrs a day.
all do,
until 2010 when LED BACKLAMPS HIT THE STREETS
POST 101.
Also the internal power saver must be turned off.
menu button, turn it off. on OSD
Jan 26, 2018 | HP L1906 19" LCD Monitor
My L1906 green light blinks but nothing on screen
Look for bad caps with leaking/bulging tops like all the failed monitors as shown in my albums here:
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Aug 31, 2010 | HP L1906 19" LCD Monitor
My lcd monitor HP l1906 green ligth flashing and screen
What it might be is that your battery is going out somewtimes when that happens the monitor will start shifting colors
hope this helps!
Jul 06, 2010 | HP Computers & Internet
Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power lcd green light keep blinking. Any solution? thx
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Feb 01, 2010 | HP L1906 19" LCD Monitor
HP L1906 lcd monitors won't display anything
Yes you got badcaps!!! www.badcaps.net examples of what they are and what they can do and this is one of them. U/You can change out these caps and see if it fires back up again.
Even bulging caps are still issues I just fixed a emac with bulging caps as the emac would freeze not when i put in the new caps the ****** is doing great!!!! I would suggest you do the same.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | HP L1906 19" LCD Monitor
HP L1906 Flat Screen Monitor Power Light Flashing
http://www.fixya.com/support/t558081-monitor_will_not_power
Jun 01, 2009 | HP L1906 19" LCD Monitor
HPl1906 lcd auto off and on blinks
Check the power regulator AS431A
Mar 21, 2009 | HP L1906 19" LCD Monitor
TV will not turn
Please unplug the tv for 30 min and then plug it back to power supply and see if the lights are blinking again...
Good luck......
Jul 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
HP L1906 19" LCD Monitor Logo
113 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
