Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My washer will fill with water but then will not run. For a while I could get it started by slamming the lid, but even that will not work now. Do you know how I could fix it?
  • Whirlpool Master
  • 8,220 Answers
What you have is a bad lid switch. The lid switch replacement video is here:
How it works: Direct Drive washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 23, 2010
Testimonial: "It is what I expected, but since I know hardly anything about appliances, it is great to get confirmation from someone who does. Thanks"
SOURCE:
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
For awhile now i have been having to slam the lid to get the load to finish after it first fills up with water. Now today even slamming the lid wont work. HELP
you have 2 screws on each side of the lid, make sure they are thight. one side of the hinge activate the lid switch. if that dont work then you damage the lid switch. replaced.
Feb 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Water fills Cycle won't start
Often the lid switch needs replacement. I can become cracked from the lid being dropped.
Nov 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
579 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
