Question about Samsung HCN529W 52" Rear Projection Television
No picture. Power's up, can hear sound but no picture. change to other input's same results. Can not pull up any visual image
    New Friend:
Power def board is bad i have been trying to find out what exactly on the board is bad but have had no luck.
Posted on Jan 18, 2011
SOURCE:
No picture or sound on home Television as a result of No signal or vedio
check the input lead . they do get pulled loose sometimes by pets , etc
Oct 10, 2016 | Televison & Video
Tv has sound but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 06, 2016 | LG 50PK550 50 HDTV Plasma TV
What part(s) should I order to repair a RCA LED TV that does not "turn on" correctly. When it powers on there is flash of a image but goes away quickly and no sound.
sadly since we can not see the set it makes it tough to diagnose unless it is a huge TV then fixing it might be more costly than getting a new set from say Walmart .the buy and try method usualy cost way more than a repair shop.
Nov 18, 2015 | RCA Televison & Video
Why do i have no picture on my philips 42pfl9632d/10 tv. p
Can you hear sound? Is power light on? Where did the smoke come from?
Jan 10, 2015 | Philips Televison & Video
I have a 42'" LCD. IT IS ABOUT 3 AND 1/2years old.
Hi evansw591,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 25, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jan 13, 2011 | Televison & Video
Screen went black/blank can hear sound no picture, cannot change source or access menu LN-S4692D
Your inverter circuits and/or power board need servicing.....
Either three fault scenarios are happening:
1. the inverter circuits are not producing AC ripple too the CCFL lamps that illuminate the LCD glass panel.
2. the power supply board is not feeding 24vdc - 12vdc sustain voltage too the inverter circuits. Meaning, no dc high voltage output from the power board.
3. The timing control circuit (LCD Board) has shorted switching devices or on-board memory has failed....which causes data/dc loss at the input which results in the inverters canceling load power (lamps). The sync data between inverter and LCD Board are absent. This will result in a 'NO LIGHT' condition on the LCD display.
Number 3 is a rare case, its usually #1 the inverters need servicing.....
Nov 10, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
No picture
your projection bulb needs replacement i think...if i got you clearly!
Aug 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Trouble with a Sony KDF-E50A10
sounds more like the video control board to me. You'll find that video drive is fundamental reason why these go 'black'
Mar 05, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Samsung HCN529W 52" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
Ekse
