Question about Ovens
I need some help with my Welbilt Microwave Model #MR 90T. I somehow while cleaning it put on the child lock & I cannot get it off. Can you help & why do I have to pay for this. I tried to download a manual however it was unavailable.
  • smogle Oct 23, 2010
    Yes I did try unplugging it several times
  • 3,247 Answers
It does seem to be difficult getting manuals for the Welbilt Microwave ovens.
I have not seen one of these before so I am just guessing, but if the microwave has childlock button then keep it pressed for 10 sec or so and that should disable the childlock. If not try other buttons like stop/ cancel or start.
I am assuming you have already tried to switch the power off and on and that has not helped.
But if the keypad is not responding then it could not be the child lock but the keypad has come to end of life and needs replacement. Not sure if they still make these - so might be hard to find a replacement keypad.
Posted on Oct 23, 2010
  • Sam Oct 23, 2010
    Please suggest your responses to the other options that I have suggested other than turning the power off and on.
SOURCE:
I have double wall unit Thermador oven. After self cleaning, the door can not open. Or may be I hit the panel lock , so the door is lock. How to unlock?
Hello April,
If any OVEN FUNTION is being used...
The controls cannot be LOCKED off...
So no... REQUIRES PUSHING 2 buttons & holding
for four (4) seconds... (not likely to be accidental)
The steps to Lock & Unlock are the same...
(see reference page (click here)
Thermador SCD302 Care And Use Manual Child Lockout
Touch and hold the COOK TIME pad and
the STOP TIME pad simultaneously for 4
seconds.
Likewise SELF CLEANING is described in great detail.
(double click this URL)...
Thermador SCD302 Care And Use Manual Page 29
ELSE...
Please contact THEM if you have questions or comments.
Phone: 1-800-735-4328 or reach THEM through their
website at www.thermador.com
Hope this helps
Carnac the Magnificent
Dec 20, 2017 | Thermador Ovens
When I try to turn my oven on, it says LOC. I don't know how this happened or how to reset it. Stove was in the house when we bought it a few months ago.
That message is normally visible when cleaning the oven at high temp. Or it is the child lock. Did the owners ask if you wanted to buy it and you said "No thanks" :>)
Try removing the power plug at the back for 30 seconds and reconnect. If that doesn't work Google
make model manual
Removing the child lock often just involves holding two or three keys for a few seconds.
Apr 22, 2016 | Ovens
Child lock
I can't find any mention of a child lock in the manual:
https://drive.google.com/open?id=1Ja2o9qZPTI809jaklqZFyIuHtspje_cNC0egEcUE6cf0TJ0Sc888U_0Q3s0OrYgE9iepD1Oq3feZZNKX
It seems to only lock when it is in self-cleaning mode @ ~320 degrees centigrade
Feb 20, 2014 | Candy FP855 Electric Single Oven
Turn off child lock
Can you identify the model of the oven you need help with or anything like that? Not all child locks on ovens are configured to function or be utilized the same way.
Sep 22, 2013 | Ovens
Lock electric oven
is this for child protection, you could put it into cleanning mode then turn the unit off it will stay locked till you turn your oven back on , could also trip the braker , Just a thought
Dec 03, 2011 | Ovens
How do I remove the child lock message on my Panasonic Inverter Microwave?
Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
Aug 20, 2011 | Ovens
I need a manual for a Welbilt Confection Toaster Oven
I have manual for welbilt model cv6311
Jan 31, 2010 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Frigidaire Gallery Series Oven Locked
Not familiar with this particular stove, but it sounds like you activated a child protection lock. To turn these on and off, you have to hit that lock icon and hold it for 4-8 seconds for anything to happen. This is so that the kids won't have sense enough to unlock it, assuming that you locked it to keep them out!
Also, frequently they work  in stages. Hitting it one time (for 4-8 seconds) will lock the panel, hitting it another time will unlock it, hitting it a third time might lock the door, and so on. So RTFM, or just keeping hitting it multiple times for 4-8 seconds each, and see what does what. But the manual should tell you everything you need to know. You can go to the GE website, or to managemyhome.com, which is maintained by Sears, and you should be able to find a PDF copy of the manual if you don't have the manual that came with it.
Feb 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
