On the back of the router there is a reset button. You may need to use a paperclip to get to it. With the power on, push in the reset button for about 30 seconds. Release the button, and let the router cycle thru lights. The router should now be reset.
Normally the user-name & password for d-link routers are "admin". If it is changed by someone or forgotten, then there is a reset switch with a pin-hole at the rear of the router. It resets the router to factory settings. But this will erase the old settings required for your connection.
Which password for login password or security key. if you forget the login password then you reset your router and put the password admin, and if you forget security key then lo problem login and open the router go the wireless setting and change WAP or WPA1 what ever you select your pre shared key.
Press and hold the reset button on the rear portion of the router. This will reset the old password. Make suer to log back on to your router using the username administrator and password admin
Yes, you can reset the password on your D-Link DIR-300 router. To do this, follow these general steps:
Access Router Settings:
Connect your computer to the router either via a wired or wireless connection. Launch a web browser and input the IP address of the router (frequently 192.168.0.1 or 192.168.1.1) into the browser's address bar.
Login:
Enter the router's username and password. The default credentials are often admin/admin.
Navigate to Password Settings:
Look for the "Setup," "Wireless," or "Security" tab in the router settings. Find the section related to changing or resetting the password.
Reset Password:
Follow the on-screen instructions to reset the password. You may be asked to enter the old password before creating a new one.
Save Changes:
Save the changes and reboot the router if required. Please note that the exact steps may vary slightly based on the router model and firmware version. If you Need More Router Support visit: Geek Squad Assists.
Resetting the router would clear the username and password. The you can go to 192.168.0.1 in your browser and set a new username and password. D-Link Router reset Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank. When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds. The user manual is on this link: http://www.scribd.com/doc/2091490/DI624-manual If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
