Digital Labs DVD Player
Did you ever get your DVD player fixed? I'm having the same problem. It just spins, says its loading then just shuts down. I bought it at Christmas and am just now taking it out of the box BRAND NEW. I can't seem to get any help on this.
  • Anonymous Oct 13, 2008
    Same thing - it won't play - the disc just spins!
I had a similar problem - only to find that the player had "eaten" another disc and it was inside the player! I was able to shake it out and it works OK now, but I'm sure it will happen again.
Posted on Nov 05, 2008
The digital labs k715 portable dvd player says no disk when there is a disk inside.have tried several disks.please help
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Sep 09, 2011 | Insignia NS-PDVD8 Portable DVD Player
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
DVD Jumper digital copy is wmv -loaded on mosaic,
your player seems not to support the .wmv video format,
to watch it on pc try another video.player like KLMcodec, update the windows media-player codecs or useother freeware videoplayer software.
some programs give you the chance to change
the video formst of a film,
change the format of file from .wmv to .avi and reupload onto player
Jun 13, 2009 | Creative Labs Zen Touch MP3 Player
Zen player stuck on -shutting down
Try to find a small hole with the text "Reset" next to it. Find something small(paper clip for instance) and simply just press the button inside the hole, you will hear a small "click".
Jan 25, 2009 | Creative Labs ZEN Vision:M Digital Media...
My Zen mp3 player is stuck or frozen on "Shutting off" mode.
when off hold play down. then turn on(while holding play). then theres a recovery menu go to clean up.
Dec 28, 2008 | Creative Labs Zen Micro MP3 Player
Portable DVD Player problem
The inter lock is sensitive add a little length to tab mine did the same
Aug 28, 2008 | Televison & Video
I turn on the mp3 player and get a shutting down screen..
there's no fix for this problem yet.
you can try loading new firmware
or try this if it works let me know
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Jan 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Can't get a disk to play
I've seen failure of the spindle motor to cause problems like this. Problem can also be a leaky diode in the power supply.
Nov 19, 2007 | Panasonic DVD-S35 DVD Player
Frozen Out
Are the music files supported by your player??? if not you'll have to load in the right files. Also try this, make another folder where your music files are and put your music in it.
Jun 16, 2006 | Creative Labs Nomad MuVo TX MP3 Player
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
