My pc will not bootup at all, no Beep code at all, I can only hear fans is moving and light is dark orange. What went wrong???
    Brigadier General:
  • 8,909 Answers
Probably the power supply is low output voltage as you say a light is dark orange, from that I pressume there is the wrong voltage on the lamp.
Posted on Oct 23, 2010
SOURCE:
Cdc-m computer will not come on the on light works case fans comes on but that is all
Do you mean that your computer does not turn on just casing light lit on and Fan runs only? What means new, memory and case?
If just lights on, fan runs but no image on monitor or blank screen, you should hear some kind of sound form inside of the CPU casing. This is called beep code. If you hear continuous beep or 3 same beep with same length, it means your motherboard is missing RAM, just connect it properly. If does not work or stop try a good RAM installing to see the result and plug your this RAM to a working machine that have the same kind of RAM.
If you hear one long beep with two short beep After PC switching on, or Two long beep with one short beep following - that means your Graphics card is not connected properly, or damaged or miss matching. If you do not have any beep code after switching on the machine, your motherboard may not have build in emergency speaker. Try to clear this things first. Please mention details of your computer with model number of your motherboard. Let me know updates.
Jun 25, 2012 | Computers & Internet
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
I recently moved my dell inspiron 530s desktop from the basement to the second floor and now everytime i plug in the computer to the outlet, the fans start and the an orange light lights up the power...
hi there:) do you hear any mother board error codes (beep,beeps or beeping) when you try to start the machine?...do you see a prompt to "enter setup" or anything else for that matter?
Jul 30, 2011 | Dell Inspiron 530 Desktop Computer
My Everex NC1501 stepnote laptop won't start up, i push the start button, my laptop sounds like it's about to start. There is nothing on the monitor (the monitor does not even come on), but I...
Most laptops use beep codes to isolate startup problems . You may hear something like beep beep-beep or a combination
The beeps tell you why it's not starting ... if you hear the sounds then the manufacturers web site will tell you what the code you are getting means
Feb 23, 2011 | Computers & Internet
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
Orange light just blinks nothing on monitor
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Nov 09, 2009 | Dell Dimension 4600 PC Desktop
Beeps continously and has orange color
The beeps you hear are BIOS Beep Codes. Sort of a 'Morse Code', if you will. So many short beeps, or so may long beeps, or a combination of short, and long beeps, making up a code.
This is the computers way of telling you something is wrong, and an area to start looking in to find the problem.
BIOS = Basic Input/Output System. A small, (Usually 64MB in size) program that is on the BIOS chip. (Chip is a slang term for Integrated Circuit. The BIOS 'chip' is soldered to your motherboard.
http://en.wikipedia.org/wiki/BIOS )
How to read that BIOS Beep Code? This becomes a little more difficult, as there are two main BIOS program makers, and every series of computers may have a different version of that program. (Award and AMI. Award and Phoenix merged)
HOWEVER, listen carefully to those beeps. Listen for a continuous series of beeps, then a pause, then the series of beeps again.
Compare what you hear to this chart,
http://www.pchell.com/hardware/beepcodes.shtml
A common problem is that ram memory stick/s may have become loose, or the ram stick is defective. (Ram 'stick' is slang for ram module)
Try re-seating your ram stick, or sticks if you have more than one.
The orange light means your harddrive isn't active. That lamp, (light), that you see is the Harddrive Activity Lamp. Red means it's working, (Active), Orange means it isn't.
If you have a ram memory problem, (Ram stick/s), your computer isn't going to work, which means the harddrive won't be working.
Aug 06, 2009 | HP Compaq dc5100 Small Form Factor PC...
Emerson CF4800 with SW375 receiver that does not turn on fan!
Please excuse me if you already have the answer, but I went thru the same thing and found that the actual receiver was broken. The receiver that is found in the top part of the fan itself. I was able to diagnose the problem because I have two of the same fans in the house and when I switched the receiver units, the broken fan started to work. Hope that helps.
May 30, 2009 | Emerson Fans Emerson SW375 Receiver
No beep tones on startup, power to all devices, no bootup
Just a shot in the dark...unplug power, remove battery..at least an hour . Press power button at least once in the hour.
Good Luck
Apr 04, 2017 | Gigabyte GA-N650SLI-DS4 nVIDIA nFORCE 650I...
Open Questions:
Epson Printer tEcH SupPoRt pHoNe nUmBeR:~{-126O{0O64}^-} Wngsary Epson Printer tech Support Number +1{26O{0O64}}WngLogin Repair service center to resolve all Epson Printer customer service phone Number products. Epson Printer ROUTER is an American multinational company which was founded by Michael Epson Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Epson Printer ROUTER support number, and selling of computer-related services and products. Epson Printer ROUTER Tech Support Phone Number Recently, Epson Printer ROUTER has been named the number Epson Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Epson Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Epson Printer ROUTER Service Tag or a Epson Printer ROUTER Get Epson Printer ROUTER Technical Support Phone Number and Customer Services. Epson Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 19, 2019 | Epson Computers & Internet
Computers & Internet Logo
26 people viewed this question
Ekse
Alun Cox
