Question about HP Photosmart C5180 All-In-One InkJet Printer
I bought anew Laptop running Windows 7 ,I have a HP5180 printer hooked to to Netgear printer server and I can't get the two to work together. What can I do. I tried what netgear says to do only to get my wireless connection cut off when I try and get th http//192.168.0.102 address. This even after I chane my static IP address to 192.168.0.16. Subnet Mask 225.225.225.0.
  • HP Master
  • 7,733 Answers
Go to NETGEAR Router or use an emulator at Netgear Emulators
Posted on Oct 24, 2010
SOURCE:
Netgear ps121v2 Smart Wizard does not appear
If you are running WIndows 7 64 bit, you need to run the 64 bit version of the installer. Look in the directory ...\bin\driver\MFP\Utilityx64
Also in, Windows 7 you need to run the install wizard as administrator, since it is installing drivers.Right click on SetupWizard.exe and select "Run As Asministrator".
Jan 19, 2013 | NetGear PS121 Print Server
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
My WGPS606 wont print on my Windows Vista laptop, its prints with all normall xp windows laptops and desktops, but I recently bought a new laptop and it does not print, the print says error, can somebody...
there is a proceedure for manually adding the printer ports instead of using the wizard on the software disk. Look on the disk and go to the guide .pdf file, the instrucitons are there. i tried it and it worked fine.
Apr 01, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Have a ps 110 netgear printer server Vista will not requnize it
I have no problem using Vista Home Preimum notebook that print to the NetGear PS110, and now the notebook upgrade to Windows 7 Preimum, it still works. All other computers using XP, Win 2000, all work fine with PS110. Basically, install the printer drivers to LPT1 first, then add a new local port with \\PSNNNNNN\P1, then it just work. no problem. (note that, you have to configure the PS110 using same subset ip address first.)
Mar 17, 2009 | NetGear PS110 Print Server
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at [email protected]
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
89 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
