My technics sl-ch550 cd player wont read the disc and shows a message saying no disc, if you spin the cd round by hand it will start tuning then play the disc for a bit then say no disc again. im wondering if the motor that turns the disc is broken and im wanting to know the problem so i can repair it as its a brilliant hi-fi system. Also i live in boston lincolnshire, where is the best place to have it fixed.
SOURCE:
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
  • 3 Answers
SOURCE: DVD pLayer Not spinning DVD's
if your dvd player is 5 years old or more i suggest you trash it and get a new one but if its not try to clean the lens manually with a peace of bond paper. rub the paper gently on the surface of the lens
Posted on Dec 22, 2007
SOURCE: Technics SL-MC6 CD player
a) the current CD in use is in slot 23
b) behind slot 23 is a CD left inside
Posted on Jul 31, 2008
  • 334 Answers
SOURCE: burn a cd
download the new 11 veirson and dont over load the cd and go in settings turn burn spee dto 16x not max k
Posted on Oct 14, 2008
  • 108 Answers
SOURCE: need for speed wont install
dear sir
you can install directx 9c from www.downlod.com
after that you can run NFS from you system.
need no worry.
i think your system is not suitable for windows 64 bit. its not at all a porblem.
when ever you installed winxp 64 bit in your system automatilically it will install 32 bit graphics memory card.
dont worry about that.
first of all please install driectx from www. download.com ( its free).
with regards
murali
Posted on Dec 06, 2008
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
My Technic SPD967 is not working. Whenever I put a cd in the tray and press the play button, I am getting an E message.
"E" must stand for error, either the laser decoder is faulty or the cd motor is not spinning or the laser is dirty or faulty, more investigation needed
Jun 28, 2014 | Technics SL-PD887 5-Disc CD Changer
TECHNICS SL HD81 5 CD MULTICHANGER. The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on th
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
Nov 04, 2012 | Technics Audio Players & Recorders
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
I burned a CD on my PC to keep in my car and it plays OK in the car and on my PC, but does not play on my Technics SL-PD687 5 disc cd player. It's recorded in *.cda format and it's on a CD-RW. Any...
The problem with old CD Players are that they sometimes are a little fidgety when it comes to reading CDRs.
You could try burning a new CD on the lowest possible setting, say 2x or 4x.
Also try changing the CDR brand as some cheap CDRs are prone to not reading in old CD Drives.
Try using a regular CD-R (CD recordable - record only once) instead of a CD-RW (CD rewritable - rewrite multiple times). CD-RW use a different "ink" to write the data to the disc and can be re-recorded/erased a couple of times before it loses its ability to write effectively to it.
Mar 05, 2011 | Technics SL-PD687 5-Disc CD Changer
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
Dec 08, 2007 | Technics SL-MC700 110-Disc CD Changer
Open Questions:
Computers & Internet Logo
166 people viewed this question
Ekse
Alun Cox
