I have an HP Photosmart C4640. I just bought not too long ago. Its displaying a message stating "Print cartridge problem". What can I do to fix this?
SOURCE:
pineworks
  • 4345 Answers
SOURCE: HP Photosmart C6280 printer won't print and
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
  • 4 Answers
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
SOURCE: hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Posted on Jul 29, 2009
SOURCE: Print Cartridges Refer to documentation (No function works)
I was getting this same VERY unhelpful error and the only thing that solved it for me was to buy another genuine HP black cartridge (350XL). As soon as I put it in, it cleared the error and sprang to life. As a matter of interest, before this happened, the HP Toolbox utility was also saying that the old cartridge was nearly empty. So why on earth doesn't the printer tell you the same thing??? Come on HP - get your firmware sorted. Disappointed.
Posted on Nov 26, 2009
  • 46 Answers
SOURCE: HPPhotosmart C4250 mgs "Printer Cartridge missing or not detected
There may be debris that is blocking the communication between the cartridge and the printer, especially if you are using a remanufactured cartridge. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
Posted on Mar 15, 2010
Hi I have an HP Photosmart C4385 that I bought in Us some years ago using the cartridges 74 and 75. I'm living in Europe today and I bought the cartridges 350 and 351 since as mentioned in the lable is...
Contact HP. Your printer needs to be reset to work with the European cartridges. If your printer is no longer in warranty, check the warranty on your cartridges and contact HP for warranty support on your cartridges.
Here's a link to contact HP. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&dlc=en&cc=us&product=3651156 This is a US link - you may want to start with www.hp.com/cposupport and after selecting your country / language, find a contact HP link.
I am an HP employee. I do not represent HP on this site.
Sep 15, 2010 | HP PhotoSmart C4385 All-in-One Printer
HP Photosmart displays a message saying "Printer Cartridge(s) missing or not detected" though I've just put a new cartridge into the machine. How do I fix this so I can print again?
Remove the cartridge.
Make sure that you removed a piece of clear plastic tape that covers the ink-jets. It's placed there to prevent the ink from drying-out while the cartridge has been sitting on the shelf at the computer store.
Re-insert the cartridge, and be sure that it "clicks" into place.
Apr 02, 2010 | HP Photosmart C4280 Aio Printer
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Error message stating empty cartridge but I bought it new today
sometimes it does happen. please carefully try it several times and try to doing it in different manner.
you can try wiping out dirt and other things that can prevent the print cartridge from functioning ..
you can even disconnect the printer cable from the pc while trying to fix the cartridge, and checking the cartridge installed light to know if it's right.
thanks for your question..
May 20, 2009 | HP Photosmart 8250 InkJet Printer
Printer won't print
my HP Photosmart C5180 all-in-a-one printer keeps saying the yellow cartridge is out of ink and I have put a new one in. The printer will not let me print anything. How can I fix the problem?
May 21, 2008 | HP Photosmart C5280 Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
397 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
