Hi how do i install my magic eye i've lost the instructions thanks adele.
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Oct 23, 2010
SOURCE:
I'm unable to get sky channels on my new Bush tv in my bedroom, It is connected by a magic eye,model:DLED32265HDDVDW,product:10103644.
hi make sure the RF 2 signal is turned on at the sky box, the light should be lit on the eye when the cable is connected,thanks
shaun
Feb 11, 2017 | Bush Televison & Video
I lost my cd key to Magic: The Gathering - Battlegrounds for Windows
Your best bet is to call support at 800-324-6496 and let them know the situation. They will ask you a few questions, then should be able to provide you with a new key.
Apr 16, 2012 | Atari Magic: The Gathering - Battlegrounds...
How to install acer crystal eye webcam?
i have a acer crystal webcam but i dont have the cd to it my big sis lost it how can i get it to get that for my laptop
Mar 07, 2011 | Acer Crystal Eye webcam
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My web cam
You can download the drivers from GENUIS's site:
For Windows XP
For Windows Vista
Hope that helps!
Sep 06, 2008 | Genius VideoCAM Eye Web Camera
Tv digieye
Hi.
At the back of the box there will be 2 rf outputs.
What you are looking for is the rf output 2. What you need to do is connect a rf cable from rf output 2 into the magic eye,which in turn plugs into the rf input on the tv.
To make sure that the 9v signal is being passed up the cable(this is what allows the magic eye to work)
go into services on the SKY guide the press 4(system set up) then 01 select. This will give you access to the installers menu. Press 4 (rf outlets) and then make sure that power supply is ON. Save new settings.
This will now let you use a magic eye.
http://dysonmanuals.llc.nu/
Chris.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Ekse
