Question about GE WBSR3140DW Top Load Washer
An item fell between the inner tub and outer tub. Need to remove inner tub to retrieve item.
  • GE Master
  • 8,220 Answers
This video show how it is done:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 23, 2010
SOURCE:
Washer say on screen LE and will not turn.. Also when manually turn the turn hear grinding noise too.
Grinding noises are bad. If you are lucky, you got an item (like an underwire support from a bra) between the inner and outer tub, which may be removed through the heater or drain openings in the tub. If you are un-lucky, your rear tub seal failed, causing the rear bearing to fail, or the shaft broke loose from the 3 arms of the spider which drives the inner wash tub. Either of those things is $$$ and a lot of work to repair, involving removal of the outer drum, seperation of the outer drum halves, and repair. (translation: minimum 2 hours labor if you've ever done one before)
Feb 28, 2011 | LG WM-2277HW Front Load Washer
My machine gets out of balance when in the spin cycle no mater what size of load or what type of clothing being washed. Model # A308 Ser# 870406GP. I have taken the front off and determined that the...
Hi and welcome to FixYa, I am Kelly.
Nice to see there are some A series washer still in service. Ok here goes on the what can cause this problem list.
1. The iiner wash tub.
a. Some one with small fingers needs to feel in between the outer tub cover and and the inner wash tub for missing chunks of the top of the wash tub ring. It is filled with concrete FYI. If the tub corroded and it tossed a bit of the top balance ring you will always have an off balance condition in the spin cycle.
b. Also grab the top of the inner wash tub and attempt to teeter just the inner wash tub. If it teeters there is a problem under the inner wash tub. This can be because of the mounting stem
item 24 of this link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789&diagram_id=28323416#d28323416 or the tub bearing Item 18 of the same link.
If the tub bearing is bad the outer wash tub can move indepently of the inner wash tub. The should move as one. Grab the agitator and press on 3 sides of the outer wash tub with opposing force and check for excessive moment. (FYI the mounting stem and tub bearing repairs ar not for the novice repair person.)
2. The CORK damper pads on the top of the machine base are worn. Item 22 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789 Pushing the outer wahs tub off center and against the cabinet should result in the outer wash tub retring to near center (within 2 inches as viewed from the top) If it does not return to near center there is a problem with the damper pads.
_________________________________________________________________________________
Here are my thoughts on your washer and what to consider. If your unit is in fair material condition and you do not have lots and LOTS of rust on the base I would repair it. Honestly this machine will outlast you if you have it "re-furbished" Refurbishment would be
A. New Tub Bearing
B. Mounting Stem
C. O-ring replaced on agitator shaft inside the transmission lower housing PN 2-10286
(^ ^ ^ ^ -- Must purchase transmission grease.
(there is the possibility that the Transmission drive gear would need replaced PN 2-10315)
D. Damper Pad Kit.
E. Motor mount spring and roller kit PN 2-5000
F. Both belts Items 18 and 19 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789&diagram_id=28323416#d28323416
G: Water injector kit.. No part number but still available.
I know this is probably a lot more information that you wanted but.. the bottom line is you own one of the "Cadillacs of Maytag." As long as the macine base and cabinet are in fair shape you can keep it in service with parts that are always available.
To fix your current problem it will show up when performing steps 1 and 2 at the top of the post. The unit will most likely have to have the inner and outer tubs removed to correct the problem and it involves about 2 hours of labor. You may have to find a very experienced repair person to have your unit re-furbished IF and I reiterate IF it ever comes to that.
Thanks for choosing FixYa,
Kelly
Feb 24, 2011 | Maytag Washing Machines
Water is not draining
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Nov 26, 2010 | Washing Machines
I dropped nails in the washing machine tub and they fell through the holes. Will this damage the washer if I run it, or might the nails just go out the drain? So far, I have been unable to remove the...
The inner basket may be also bolted to the transmission. If left in there, they will end up in the pump. If this is a steel tub machine, you can buy a good sized magnet, and leave it in the wash basket, near the problem area. The nails should collect on the other side, and hopefully keep them from spreading significant harm, until you can get them out of there. You may be able to **** them out with a good strong shop vac.
Jun 21, 2010 | GE Washing Machines
I have a kenmore elite washer mod.#110-27062602
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27062602&pathTaken=partSearch
Assuming that this is the Oasis type washer, see the Whirlpool Service Manual for their Cabrio washer which is basically the same as the Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It has troubleshooting and teardown procedures.
May 08, 2010 | Kenmore 22422 Top Load Washer
Underwire stuck in hotpoint WMD 940
i can try to help you with this problem. if you pop the cap off the top of the agitator you will see a nut, once you take the nut off you should be able to jiggle the agitator in an upward motion to remove it then retrieve your wire and gently slide agitator back on so as not to ruin the splines if there are any. good luck
Sep 29, 2017 | Hotpoint Aquarius WD640 Front Load...
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
Sock stuck in outer tub whirlpool cabrio
youll need to "pop" the main top.. then unsnap the outer ring that cvers the outer tub. if you look at the center of "agitator/ or bump plate depending on model" theres a small cap that will come of fand reveal a 7/16 screw remove the screw, and then oyull be able to lift the entire inner basket right out to retrieve any debris.
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Outer tub seal
you must first remove the agitater,then remove the inner tube,you'll need a spaner wrench,you now can see the tub seal,how you need to remove the 3 bolts around the bottom of the outer tub,now you can remove the outer tub and replace the tub seal,or use some 3m gasket seal,up to you,you can get a new tub seal on line for $10,let me know how you do-mike
Nov 03, 2008 | Kenmore 24032\24036 Top Load Washer
Worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
486 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
