HELP TO FIX THIS
It was when operating when suddenly my desktop stag.I restarted and restated but the only thing displayed is as below
the cover was previous removed.invalid configuration information please run programme setup.
It stops their then no any key function to let me proceed,
please help me what is this.I have tried to take off everthing still the mother board give same alert
  • 86 Answers
Ji,
Try setting the boot in the bios to only hdd(on all options if it prompts you to add a secondary).
Also had a couple of problems that sound like they could be from the same root that were an issue with the memory or a bios clash with the video/graphics card.
Try and get into the bios setup before it starts to initiate windows - usually the "del" key but it should tell you on startup if you watch carefully - i use an almost identical motherboard with similar peripherals and have had no problem when it was all set up, but i remember setting up being a bit complicated, but not exactly how.
check this site - is avout problem entering windows - you know the symptoms better than me
http://support.asus.com/troubleshooting/...
hopefully this will help :)
Posted on Jun 07, 2008
Restating 2000 odyssey after warmed up
not sure what that means.
lets start over.
your saying car runs great, cold then hot.
then hard to restart a hot engine, right?
the light thing i dont understand
first off, when you stall and engine or just key ON.
the lamps all self test (read the operators guide there)
this is only a lamp test.
odd, the most important is skipped the CEL, check engine light.
is the engine stalling?
hot restarts, fails are: many.
  1. injector leaking at shut down.
  2. ECT reads to cold when hot. can be below caused
  3. Engine thermostat stuck open and restarts are over rich and floods. that hot engine must be at 180F or more,
  4. never did a 60,000 mile tuneup this decade?
  5. Fuel pressure too high.
i do tune ups first.
then check coolant temperatures, hot. 180F min, and holding or i kick the thermostat to the curb (new stat time)
if it sill dont want to hot start
out comes the scan tool
i scan it, got DTC errors.
is ECT reading 180F ? or above?
that is start on diagnosis.
Feb 25, 2014 | 2000 Honda Odyssey
Dell stage does launch during startup and does not open
Go into Control Panel; click on Services; Under services find stag make sure it is checked to start:
Jan 11, 2013 | Dell Xps 8300 Desktop Computer (DXDWMN55)
The computer goes off on itself and then starts producing sounds what might be the real problem
If the computer is restarting after loading operating system try below options.
1. Check if all the device drivers are installed properly, if not please reinstall the proper driver.
2. Try reinstalling the Operating System.
If the computer is restarting before loading the Operating System try below options.
1. Check if the Power supply is working fine.
2. Please remove the RAM from the slots and re-fix it and check if the problem occurs.
Jun 08, 2011 | Dell OptiPlex GX260 PC Desktop
The monitor suddenly went blank and displayed "no
no signal coming out from the video card input to your monitor. better check if the vga cable is properly fix on the video card and the monitor. you may need also to disconnect the video card from the motherboard and reseat it properly.
just make sure computer is turn off when you do this.
let me know if i can help you further.
Feb 01, 2011 | HP Pavilion a1210n (ED895AA) PC Desktop
Getting a No sync message on monitor ,computer
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
May 15, 2010 | Microsoft Windows XP Home Edition
The computer suddenly shows no display
it's about the game and videocard drivers
Jul 01, 2009 | Gigabyte Computers & Internet
The computer does'nt shows the graphics when started
Find the recover cd that came with your computer and when asked to reinstall or repair choose repair. Larry
Mar 03, 2009 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Windows Xp Problem
if yu have a copy of win xp cd. what u do is insert it in yr cd rom drive then make sure yr first boot device is cd rom. now restat yr computer to boot from cd rom just as if u want to reinstall a new xp os but this time yu will chose the option "repair" on the second blue screen that will come out.
try this and all deleted files will be replaced..
NB: before yu start this process make sure yu back up yr important files to a diff drive say d: or possibly external drives incase things go wrong.
thank u
May 30, 2008 | Microsoft Windows XP Professional
PLZ HELP ME MY CHINA MOBILE IS RESTART WITH SIM
the best thing to do to your China mobile phone' is bring to the cellphone shop nearby, Special Software and Gadget to be used this operation and a skilled technician can fix your phone.
Feb 14, 2008 | Nokia N70 Cellular Phone
Computers & Internet Logo
359 people viewed this question
David Payne
David Payne
