Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w15 tuner replacement
I have a tuner fe6241 with the f connector snapped off and got a replacement or thought I did fe6241-a looks same but is missing two pins for board mount. can some one please help thanks. Jack- Glazierman.
    Genius:
  • 1,030 Answers
Yes i do believe this tuner will work even with the missing pins...i have replace these here at the shop and found the pins unused...I would go ahead and try it... i dont think there will be any problem let me know if it works
Posted on Jun 07, 2008
RCA D52w15 will not turn on, flashes three times.
Replace you flyback transformer and Horizontal Output Transistor
Sep 28, 2009 | RCA HD52W59 HDTV Projection Television
RCA D52W15. Set's ON light will come on for about 10 seconds only
On Deflection board CK cp150 2200uf 16v if it is puffed up on top it is BAD there is 2 more capacitors you need to change out as well 220uf 35v in same circuit, resolder all pins on FBT flyback Transfomer.Also Ck second Ribbon connector make sure it is in correctly this ribbon can also cause set not to come on.
Aug 08, 2009 | RCA Televison & Video
I just need to replace tuner on R.C.A. model D52W15 part # 264658
you can get replacement tuners at the following link. Call or leave a email with what youre needing.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The piece were the cable is connected to is broken
Must replace the tuner call union electronics they probably have it
Jan 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52wi5 tv tuner replacement
i have noticed that the new tuners are missing a few pins. i believe that it will work. what is the exact make and model of the set there is a tiny printing of the model above the model # i has d52w15...yx....something. you need this to cross reference the tuner. let me know and i will cross ref it
Tuner Problem
Robert,
Replacing the "F" connector is usually all that's needed unless the tuner board is cracked. You could remove the tuner - send it in for repair and re-install it... It would clearly save a few bucks!
Any shop should be able to do that one easy enough... Around here we charge $40.00 including the part to replace the "F" connector and there are shops that charge even less...
Bill
Feb 09, 2008 | RCA 20F512T 20" TV
Cable connector repair
use RCA cables instead of ch 3
Oct 24, 2007 | RCA D52W15 TV
The dreaded flashing light of the RCA
I worked on a similar one, had a bad flyback, replaced and all checked fine.
Jun 01, 2007 | RCA D52W15 TV
Broken cable connector
the easies and cheapest way is to use the audio video input. pulg the cable into your vcr & use the vcr to change channel. the other way is to replace the tuner, typically tuners sell for around $75.00 to $100.00.
Oct 29, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
