Question about Kenmore 63942 Dryer
Kenmore 80 series drier does not start inspite of proper power supply. Everything is dead.
  • 3,074 Answers
This may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 23, 2010
  • Kenmore Master
  • 8,220 Answers
Unplug it. Remove the rear dust cover and check the thermal fuseKenmore 80 series drier does - 83b8c58.jpge0474cc.jpgKenmore 80 series drier does - 89d636b.jpgttp://i.fixya.net/uploads/images/89d636b.jpg" alKenmore 80 series drier does - 8bf91d1.jpgjpg" class="h_mi" />8bf91d1.jpg5edce92.jpg
More here with a service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE:
My kenmore drier (H.D. 80 series) won't heat up. What can it be? Thanks, Joe
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 14, 2010 | Kenmore Dryers
My kenmore 80 series dryer won't heat but everything else works fine I cleaned the vent duct of all lint [ there was alot ] and checked the electrical conections
Had similiar problem once and it turned out to be one leg of the 240 volt
supply was dead. The drum motor only needs one leg (120V) to run, but the Heating elements require both legs (240v). Make sure you have 240V at the recep.
Nov 27, 2009 | Kenmore Dryers
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 Series loud rattling noise
Its called a Drum Support. Purchase at any appliance parts supply store or online from Sears or Whirlpool.
Part# 3397588 or 349241T (Pk of 2)
Jun 08, 2009 | Kenmore 63942 Dryer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmoor 80 series drier won't turn on.
I would check house breakers or fuses first.
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 80 series dryer...takes twice as long as it should to dry
no about all the time this kind of problem is caused by some kind of vent restriction start by looking over th back of the drier with a flash light and see if the vent is mashed folded over on its self or too long you only need enough to hook to the connector to the floor then go to the out side with the drier running and check to see if the drier hood attached to the house is opening i some have a plastic screen attached to the hood to keep critters out make sure that's clear rule is must have a 4" opening from drier to out side hood cant hang down under house and come back up as dryer will fill it with water over a peorid of time now easy way to verify vent restiction is to disconect vent run 1 load and see if it dries in proper time about 60 min
Dec 31, 2007 | Kenmore 659 Electric Dryer
Kenmore 63942 Dryer Logo
324 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
