Question about Sony Handycam DCR-PC101E Mini DV Digital Camcorder
When I try to replay my tapes there are thick, grey lines on the screen. Help!!!!!
    New Friend:
This is one of a few things either one the formatting on your tapes and camera are diffrent which causes the thick gray lines because they are not compatable or two the tapes are bad and the either if there disks are laser burned or if they are tapes they are smudged either way try this buy some new tapes and go into your formatting settings and see if they match that which the tapes run on
Posted on Oct 23, 2010
SOURCE:
Why does the picture have grey lines running across it when I replay the tape ?
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Dec 18, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Canon mv 830, grey horizontal lines across screen when replaying and a flashing red symdol which looks like a bowl with a slash across it and an arrow pointing down into it
Hi - I have just managed to fix this issue of grey stripes across my screen on playback on my canon mv800 by going into the audio format settings in the menu and changing the format from 12 bit to 16 bit - good luck everyone else! Sharon
Jun 12, 2009 | Canon MV800i Mini DV Digital Camcorder
Bars across picture when replaying tapes.
The tapes were recorded in LP mode and the replay is set to SP mode. Switch from "EASY" to "P" and replay and you should be OK
Apr 27, 2009 | Canon MV800i Mini DV Digital Camcorder
Horizontal gray lines in display screen and on TV
if u see them on lcd and final output also have these grey streaks then ur problem might be this u can call canon for free repairs but first try to clean ur camera head with head cleaning cassette and see if it helps otherwise call them see link
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls rate me fixya for help
Apr 07, 2009 | Canon Cameras
GREY BANNED OUTPUT
It is symptom of dirty / clogged video head.
Please use good quality mini-dv video head cleaning tape to clean head. Problem will be resolved.
Mar 16, 2009 | Canon ZR850 Mini DV Digital Camcorder
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
Grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
Jan 12, 2008 | Canon ZR200 Mini DV Digital Camcorder
Blue Lines
I have the same problem with my Panasonic and have not taken it in yet; however, understand that its a simple fix of running a cleaning tape through it.... Ill try this...
Nov 06, 2006 | Panasonic PV-GS150 Mini DV Digital...
Sony Handycam DCR-PC101E Mini DV Digital Camcorder Logo
130 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
