Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
Replaced batterys worked fine forabout 1hr. then speed went up fast then nothing. lights and horn work , batterys are charged. no response to forward or reverse controls
    Novelist:
  • 232 Answers
Unfortunatly, your batteries need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own. There is enough power to turn on the lights and honk the horn, but not enough to get the motors to work.
Posted on Oct 25, 2010
SOURCE:
Turn the key nothing happens, total loss of electrical
Please check all connections. Are lights/horn workings?
Aug 26, 2014 | 1995 Nissan Pathfinder
Rascal scooter
Could be the Throttle Pot or Speed Pot. The levers will change the resistance of the throttle pot. The speed pot feeds the throttle pot.
Move the speed pot while pushing the lever forward. If it works could be the speed pot has a dead spot on it. Also check wires loose and a mechanical issue with the throttle pot and the springs.
Apr 04, 2014 | Health & Beauty
Hi. I have 2003 Toyota Sequoia. I just replaced a dead battery with a brand new one. When connected the new battery, it started blowing horn so I did handle that with pressing the unlock key on key FOB and...
Sounds like your car is in the limp home mode. When the computer in your car fails it goes into a limp home mode that lets you drive it home at a slow speed. Sounds like when you changed the battery you may have damaged the computer. Take it to the dealer to have it checked out.
Feb 16, 2014 | Cars & Trucks
Have a1993HondaShadow Stopped at storean won't start,nothinf will work.Lights horn Etc.
First check the main fuse, then battery connections,then check battery for voltage,ignition switch. If your battery went dead you need to check the charging system.
Oct 26, 2012 | Motorcycles
Van wont turn over not a sound i put in a new battery
if it works jumping it then the starter is fine. check fusible links to see if one is blown. check all contacts, engine grounds too, for corrosion and clean if necessary.
Sep 16, 2012 | 1995 Toyota Previa
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Voltage problem when running bike
The voltage regulator should present 13.5 to 14.5 volts at the battery to charge it properly (engine at fast idle). I'm not sure if the V regulator is adjustable or not. If not, then it probably needs to be replaced. The alternator appears to be trying to do it's job, although it may have an open diode or winding if the alternator is 3-phase. An oscilloscope is the best tool to check for all three phases working properly. Good luck!
Aug 25, 2009 | 2004 Harley Davidson FLHTC - FLHTCI...
883 wont start
The battery might just be done or warn out, if you get lights when you turn the key on, and can honk the horn and everything, then it should click, if you are able to honk the horn and lights etc. and they aren't real weak, when you hit the starter it should tick, if your lights are bright and horn is loud and brake light responds quickly, then I'd ask a Harley dealer about it.
Aug 11, 2009 | 2004 Harley Davidson XL 883 Sportster
Scooter wont work
may be the battery has been damaged. you will have to replace the battery.
Jun 30, 2009 | Elite Pride Go Go Traveller 3 Wheel
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
159 people viewed this question
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Dan Kostella
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
