Question about Acer Aspire 4720 Notebook
Advent 5431 laptop,changed screen and inverter..problem is screen is mashed up ie cant see anythink at all only when connect to external monitor when i view both screen laptop and external its like the screen on laptop has frozen and mouse pointer on screen wont move..funny thing tho if i put video on in full screen only and turn brightness down on windows media player i can workout a Perfect Picture on laptop screen..but if i turn the brightess up screen just go haywire..would a faulty cable from mb t monitor really cause this..to be honest i think i have a faulty graphic chip.:(
    Guru:
  • 453 Answers
Hi i think that the problem is a bad contact; the video signal was attenuated; you can't see anything; the solution is warm well the video connnector with a hot air; use a good liquid to clean before. and be sure that the new inverter is fine and the new lcd work properly
Posted on Oct 23, 2010
    Brigadier General:
  • 8,909 Answers
It might be a bad connection on the cable supplying the screen.
It can't be the graphics driver as the brightness is controlled by the screen and invertor speeds.
If the connections are OK, I think you have a faulty panel as if you turn the brightness up the picture goes weird making me think the screen is faulty as the processing of brightness and contrast etc is carried out within the screen itself..
SOURCE:
Connecting from laptop to tv wont work now. It was working fine previously
Check the display settings on your laptop to see if the external monitor output is disabled. There is usually a function key on the keyboard with a picture of a monitor on it which can be used to switch between internal & external monitors.
You may also need to try on another monitor/TV or change the HDMI lead.
Sep 27, 2012 | pcb Advent 5711 5431 Laptop M/b U41iix...
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
Igot a blank screen when i start my sl410, i didn't find anythink.
Possible inverter if the screen doesn't work, but an external monitor does.
Feb 04, 2011 | IBM Lenovo ThinkPad SL410 Notebook
Advent 5431 screen all mashed up ie cant workout what anythink says on the screen at all,when i plug in external monitor screen is ok..changed screen with a working laptop screen and changed inverter still...
Most probably you have a defective LCD screen cable. This is the only possibility left since you have changed the LCD screen & inverter, & an external monitor works fine. Check your LCD screen cable & replace it if necessary.
Oct 22, 2010 | Acer Aspire 4720 Notebook
Hi my screen has gone blank on my laptop advent 5431 any ideas
I have gateway mx7118 and my screen went dim when power on. I connected to a external monitor and no pic on the monitor.
Could the problem be I need to replace the LCD invertor?
Nov 29, 2009 | Acer Aspire 4720 Notebook
My compaq preasrio r3000 black screen cant conect to an external
have you any other A/V ports out ie Svid etc if so try that via an A/V lead, if that works reset your bios settings to minimal settings, if that doesnt work search the 'net someone somewhere has had the same problem! try shining a flashlight/lamp onto the screen whilst booting up, if you see anything on the screen then your inverter is definatly gone and yes it could still be your inverter! your laptop may have software/hardware issues with an external monitor?
Mar 09, 2009 | Compaq Presario R3000 Notebook
MEGGAPIXELS OF THE ADVENT 5431 LAP
the answer to your question is 1.3 megapixels....hope i was helpful to you....
Dec 16, 2008 | Recoton Advent Advent Q2035A 20" TV
Hi milovacka here
Could be. I would refer to qualified service personnel. Is there an icon on the laptop keyboard to change between the internal and external monitor? it would look like th outline of a computer screen.
Aug 20, 2008 | Computers & Internet
Acer Aspire 4720 Notebook Logo
179 people viewed this question
Ekse
Alun Cox
