Question about Dryers
The dryer won't start andnone of the electronic choices on the dial work
  • 3,074 Answers
Sounds like the timer motor, here is a website that will tell you all you need to know. Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 23, 2010
SOURCE:
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Dryre won't shut off
please remove vent line from dryer,turn on see if timer starts to advance if so...possible vent line clogged...or dryer has plugged with lint..call if need assistance michael doctor airr appl.repair 843-384-8474
Mar 26, 2010 | Dryers
Some days electric dryer works fine and others it won't start
If you can get to the timer, spray a good electronic contact cleaner inside while rotating the dial. Also check the door switch for solid mounting and sung wire connections.
Apr 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Open Questions:
Dryers Logo
27 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
