Question about Garden
Need User manual for Homelite Blower Mdl: UT08550
  • 8,197 Answers
You can get the manual on the link below.
http://www.homelite.com/product_manual/file_url/29/UT08550_951_050_eng.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 23, 2010
SOURCE:
I do not know the oil-to-gas ratio to mix/buy. My husband passed away, and I cannot find the manual. Help, please. THANK YOU
Can you find the model number on the Homelite Mighty Lite BlowerVac?
For the UT08520 and UT08921 26cc blowers and the UT08550 and UT08951 blower vacs, you can mix the Homelite Premium Exact Lubricant with gasoline following the label directions. For other synthetic oil additives, use 2.6 oz of additive per 1 gallon of gasoline. (It's 20ml to 1 l if you use the metric system.) That's a 50:1 ratio (gasoline to additive).
Many Homelite Blower manuals are available here: http://manuals.homelite.com/documents?page=5 . You should try to find your exact model and then check the manual to confirm that your model blower vac uses this same ratio of oil to gasoline. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Sep 06, 2013 | Homelite Mighty Lite Blowervac
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Need to know gas mixture
GasolineLubricant
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
My Homelite mightylite blower vac starts but won't stay on unless choke is closed down the unit is only one season old. The unit is supposed to be in warranty for two years but Homelite said not the...
The unit is under warranty. The person you talked to must be new. Find a warranty service center in your area. Take your receipt with you and they should be able to take care of it for you.
Good Day
Dec 13, 2009 | Homelite 'Yard Broom' Leaf Blower
I nww=eed to know the fuel mixture for my homelite gas blower
If you ran plain gas in a 2-cycle engine and it seized... you need to buy a new one. 2-cycle engines depend on oil in the gas for lubrication. If you run straight gas, there is no lubrication, the engines overheats and seizes. The end, unfortunately.
May 25, 2009 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
Garden Logo
75 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
