Question about Dayton Heating & Cooling
Need a wire diagram for the Dayton motor model 6k148q to make the motor reversable
SOURCE:
  • 72 Answers
SOURCE: dayton heater/ need wiring diagram /
What's the model number?
Posted on Jan 28, 2008
SOURCE: Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
You do.I too have a Dayton replacement motor.Works great.
Posted on Jun 06, 2009
  • 614 Answers
SOURCE: i have a dayton 1 1/2 h.p electric motor, and need
Line is L1 L2 L3 to line voltage. wire nut 4-7 together wirenut 5-7 together and wirenut 6-9 together connect 123 to line for low voltage 123 together 456 together 679 together. This works on all dual voltage 3 phase motors. Some of the newer Daytom motors have a plug that you just turn for changing voltage. Rudty
Posted on Jun 07, 2009
  • 148 Answers
SOURCE: AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
Posted on Jun 21, 2009
  • 674 Answers
SOURCE: I bought a replacement Dayton electric condenser
The tan/white wire can be insulated/capped and not used. Use and ohmmeter to take a resistance reading between the tan/white wire and L1 & L2. There will be no resistance between the tan/white wire and one of the others. This will be the common wire. Connect it to one side of the contactor. Connect the tan wire to the fan terminal on the contactor and the other wire to the common terminal on the capacitor (that is if you have a 3 terminal capacitor, if you have a 2 terminal capacitor connect tan to one side and the other wire to the other). Then connect the other side of the contactor to the common terminal on the capacitor (on a 2 terminal capacitor connect the contactor to the side that doesn't have the tan wire on it).
Posted on Aug 16, 2010
Wiring of Dayton 6k794ae
Check the name plate as Dayton is real good about putting the diagram right on it. If it is there, you can post a picture of it and I can help you from there.
Aug 20, 2018 | Dayton Pool & Spa
Reversing a Dayton motor model # c286c1 motor
electric motor reversal requires the field winding to be reversed
this is best done by an electrical motor repair electrician as not getting it right can burn the motor out
Nov 26, 2017 | Dayton Heating & Cooling
How to reverse a model c286c1 Dayton 3/4 hp 115 230 v motor
https://www.grainger.com/category/hvac-motors/motors/ecatalog/N-9xz?okey=DAYTON+MOTORS&mkey=DAYTON+MOTORS&refineSearchString=DAYTON+MOTORS&NLSCM=17&EndecaKeyword=DAYTON+MOTORS&searchRedirect=DAYTON+MOTORS&sst=subset&cm_mmc=PPC%3A+Yahoo+Supplier-_-DAYTON+MOTORS%26gt%3BDAYTON+MOTORS-_-DAYTON+MOTORS%26gt%3BDAYTON+MOTORS%26gt%3BBroad-_-DAYTON+MOTORS
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 25, 2017 | Dayton Dryers
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 21, 2013 | Pool & Spa
I have motor dayton model 9ncg4 now the wire is110 conected i need to conected 220 i need the diagram
I reversed start winding to reverse motor now it runs the right direction but it keeps starting instead of running smooth
Sep 27, 2012 | Dayton Wire Wheels Motor 2 HP 3450 230 V...
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Heating & Cooling Logo
103 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Paul
Paul
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
