Question about LaCie 1TB D2 HD Quadra FireWire 400 Hard Drive
How can i open lacie and retrieve "my documents" folder?
  • LaCie Master
  • 7,733 Answers
Go to MY Computer.There you will find any device.right click on it and click open.
Posted on Oct 24, 2010
SOURCE:
I accidentally emptied my 'Junk' folder on my hotmail account, Is there any way to retrieve the documents I deleted?
Check the "deleted" folder , if not there, post back and there is something else you can try.
Apr 13, 2013 | Computers & Internet
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Can't open folders in same window
it is a trojan download trojan remover and also run malawarebytes they are free and safe to use
May 07, 2009 | LaCie 320GB P3 Firewire External FireWire...
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
How retrieve backup doc.
All documents are usually saved by default to your "My Documents" folder.
Nov 25, 2008 | Gateway Audio Players & Recorders
Sync software/empty folder/ slow backup/
hello frustrated one,
the back up feature is application dependent, not hardware dependent, misfortunately. Gotta love sales guys.
my understanding is that these will back up data files, not application files.
backup speed is dependent on how it's connected. in ascending order.
USB 2.0
Firewire
Ethernet
simple situation..just need to know what your connecting with.
Also, you may want to consider an online backup utility, as well. I use one from here
May 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie Hard Drive, FA Porsche model
If the disk is FULL then you have used all the space, this is not uaually a fault but you may need to look at the data on there and delete any old stuff you dont need. IF you need it all then you should buy a larger capacity drive.
use "my computer" to see the drives connected to your PC. The lacie should be easily identified by it's name. Double click on the drive and you can explore the files/folders.
HIH
May 06, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Files locked in hidden folders
u can retrieve it easily it depends on the type of file if its a music,video file open through the real player that is start the real player and ask for scan of videos or audio files it wil automatically locate the hidden file too;
if its a word document then search through acrobat reader
Apr 11, 2008 | Computers & Internet
Lacie 250 gb gives error while accessing some folders
I took mine to a place to get it fixed and they said it was beyond repair and the only option is to recover the data and transfer it onto another disk
Jan 18, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie CD-RW CD-ROM doesn't have installer for Macs?
these are the drivers and support for the MAC.... http://www.lacie.com/support/drivers/index.htm?id=10011 I hope this helps if not email me at troublerst at hotmail and I will see what else i can do
Jul 11, 2007 | LaCie (300705u) CD-RW Burner
LaCie 1TB D2 HD Quadra FireWire 400 Hard Drive Logo
71 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
