Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52wi5 tv tuner replacement
I have a fe6241 tuner with the f connector snapped off and got a replacement but it is shy two pins for board mount and can't find correct tuner can some one please help ? thanks Jack- Glazierman
  • dagwood682 Jul 17, 2008
    Can someone please tell me if the RCA part# 264658 is the same as the FE6241 for the RCA rear projection model # D52W20. I have ordered and rec'd a new tuner (264658) but 2 additional pins are missing on the opposite end of the F connector on the tuner other than the 2 that are originally missing.
    Looking at the PCB it doesn't look like there are any traces or ground plane that connect to these two spots, but I'd like to be sure before I solder it into the board.
    Thanks
  • Randy Sheppard May 11, 2010
    I have no idea what you need. MORE INFO! What is the MAKE and MODEL of this set?
  • 82 Answers
RCA 264658 Tuner
Posted on Feb 05, 2010
    Genius:
  • 1,030 Answers
I have noticed that the new tuners are missing a few pins. i believe that it will work. what is the exact make and model of the set there is a tiny printing of the model above the model # i has d52w15...yx....something. you need this to cross reference the tuner. let me know and i will cross ref it
Posted on Jun 24, 2008
I have a RCA 52"
This happens all the time. It just might be fixable. This connector is known as the "f" connector or female coaxal connector. Most average electronics technician can fix them. This connector is attached to a component called the tuner. The tuner is what takes the signal and selects the channel the tv recieves. To replace the connector it means removeing the cuircit board that the tuner is on and then removeing the tunner, disasembling the tuner. Now until you find a good tech, there is another option... take an vcr and use the rca inputs on set. essitally tunning the set through the vcr. Now you will have to change channels through the vcr. but it will work. also there is a chance that the tuner might be damaged. just depends on the damage that occured when the connector was broke off..,let me know if you need any more help
Jun 03, 2011 | RCA HD52W56 52" Rear Projection HDTV
The cable connector has been broken off from the outside, is there any way of fixing this without replacing the entire board
Yes...if you can remove the board from the TV safely. You will have to unsolder the tuner. Then remove the sides of the tuner to inspect the damage. You will need to replace the RF connector with an RCA part #215543. On another note, find an old TV repair shop and see if they can salvage a tuner from an identical TV. This is actually faster and easier to repair. Note this, just replace the tuner, not the main board. The salvaged unit may not be serviceable. Thanks for asking and show all hands of support!
May 16, 2011 | Zenith B32A24Z 32" TV
The cable connector has been broken off. is there any way of fixing this without replacing the entire board
With most tv's I've serviced, the cable connector is connected directly to the tuner module. The tuner module may be damaged beyond repair, depending upon how much physical force was applied to the cable connector. I would take it to a reputable repair shop and let them provide you a honest estimate of repair. They may be able to resolder the cable connector to the tuner module.
The antenna/cable in threaded piece has come out of the back of the tv. How can I fix that. I tried to put it back but it won't stay. I think I need a new one.
These sets have what is known as a on board Tuner. This means that the Tuner is not replaceable without replacing the entire Board. The good news is that you can replace the Cable/RF connector as long as the shield it attached to is not broke or too bent. Most of the Cable/RF connectors used in these sets have PCB mount . You will have to remove the Signal Board and unsolder the center connection of the broken connector left on the Board. Remount the new
Connector and solder the center connection. You may need a collar nut to secure the Connector the the shield.
I hope this helps,
Skyassoc
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hello the connector on back of my tv came loose how can i diy
You need to remove the tuner from the main circuit board, resolder the cable connector to the metal tuner case, and resolder the connection inside the tuner from the connector center tab to the tuner circuit board.
Removing the tuner requires "solder wick," a copper braid that soaks up the solder as it melts so it can be freed from the board.
Resoldering the connector to the tuner case requires high heat from a soldering gun to get it hot enough fast enough to make the connection. A regular soldering iron won't do the trick.
If the connector has been broken off completely, replacements are available from a couple of on-line vendors (I use a company call MCM Electronics www.mcminone.com.)
If you are not comfortable with electronic soldering and working on TV's, you might want to get an estimate from a shop for this repair. It should be under $100, depending on the shop's rate.
Dec 09, 2008 | RCA F27450 27" TV
Tuner
whats wrong with the old tuner? did the connector break? depending on the damage the connector can be replaced to replace the tuner right out i would call a medium difficult level. it invovles removeing the signal board the board with the tuner on it simply unsoldering and replacings care should be taken not damage surface mounted components. at the shop it is possible we repair these tuner which involves opening the can tuner and soldering a new connector to the can of the tuner.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w15 tuner replacement
yes i do believe this tuner will work even with the missing pins...i have replace these here at the shop and found the pins unused...I would go ahead and try it... i dont think there will be any problem let me know if it works
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help me
If you are decent with soldering iron you can repair it yourself. Remove the back, and remove the signal board from the unit. Unsolder the Tuner from the board( If I've lost you already, call a TV shop for repair) Remove the shields on the tuner and inspect for damage to the tuner itself. If the board is in good shape, replace the RF connector with RCA # 215543. you'l have to unsolder the old ends connector ( the wire thats still there broken ) from the board, then attach the new end, and solder to the board. Then using high heat, solder the Connector to the tuner housing. Replace tuner on board, hook everything back up, and you should be in business.
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
Tuner Problem
Robert,
Replacing the "F" connector is usually all that's needed unless the tuner board is cracked. You could remove the tuner - send it in for repair and re-install it... It would clearly save a few bucks!
Any shop should be able to do that one easy enough... Around here we charge $40.00 including the part to replace the "F" connector and there are shops that charge even less...
Bill
Feb 09, 2008 | RCA 20F512T 20" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
303 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
