Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
I have a Yerf-dog 3203 go-kart with a 6.5 HP Tecumseh engine. It's a pull start, and the pull cord broke. I can't get the cover off to fix the pull because the cover doesn't have screws. It has metal flat head plugs with a hole in the center. How do I get these plugs out to get the cover off without ruining the housing?
    New Friend:
Dig in, you take the whole cover off not just the front cover were the cord is take off the gas tank remove the exhaust heat shield pull the plug wire. everything is bolted on not screwed on. leave the valve cover on. rotate the pully counterclock wise replace the cord ,
Posted on Dec 20, 2010
  • 3,074 Answers
They are rivets, you will need a drill, the bit should be just big enough to fit the pin, once you start to drill it will come off. You can put screws back in once the repair is made. Good Luck Tim
Posted on Oct 23, 2010
6ya staff
SOURCE:
Tecumseh lh318sa auger does not work
If you are asking about the pull cord and when you pull it the engine does not turn and the cord pulls super easy it generally means that the dogs inside the cove assembly are not engaging. This may be caused by a broken spring or dog inside the pull cord assembly. You would need to carefully remove the assembly cover from the engine and pull the cord to see if the dogs are protruding from the assembly if not you would need to repair or replace the parts as needed if so then you would have to check if the will still extend under strain, if not then repair if they still protrude under strain you would have to examine the engine where the unit was removed and look for damage or wear and replace parts accordingly. If you are in fact asking about the front or snow auger on the snow blower itself then the most likely answer would be that you have sheared a pin which holds the auger to the shaft that rotates it. The shear pins (as they are called) are designed with softer metal to break if you hit a large piece of ice, stick or rock that may damage more important and expensive parts of the blower if they stayed intact during the incident. To fix this merely find the hole in the auger along the shaft that is no longer pinned (the auger should spin freely) spin it to line up with the hole n the shaft (which may still have a broken piece of the shear pin in it) drive out any remaining pin with a punch and replace with the appropriate pin for your machine. If the pins are intact you may have a bad belt, pulley, or tensioner and you would have to move further into the repair process.
Feb 16, 2015 | Tecumseh Snowblower Snow Blower Starter...
I have a yerf dog 6.5 hp motor go kart that the
Starter pawl or improperly wound string inside the starter housing most likely.
Sep 07, 2014 | Garden
5 hp tecumseh engine on manko go kart starts and idles high but when gas i pressed it stalls out
check for blockage ion the main jet and loose carby or bad gasket as you may be running too lean . Check float level is correct.
Sep 14, 2013 | Tecumseh Enduro Horizontal Engine 5 HP...
Yerf Dog Tricycle needs bearing.
not sure who sells the bearings,but i just fixed my little girls yerf-dog trike using BB's out of my daisy. they would only work on the bottom of the forks and was easy to do first putting new grease in the frame and sticking the BB's in to the bearing cuppling then sliding the forks in. good luck
May 23, 2012 | Radio Flyer 32s All-terrain Steel and Wood...
How to open the cover of the rope starter cord of a Yardman MTD Electric 5 HP 24" Tecumseh engine model no: 31AE600161 The white pull cord broke off.
If you've never performed this sort of maintenance before, then you should not try it without assistance. The spring is under considerable tension and can snap out suddenly and inflict quite a bit of damage to you.
I recommend that you contact your nearest authorized service center for assistance, or search youtube for a comparable video.
I trust this information proves useful.
Dec 04, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
How do you replace the pull start cord on a 5 hp tecumseh snow king engine, I can't find my manual. Pull start cord broke last snow we had.
I recommend contacting your nearest authorized service center, or you can download operators and service manuals typically online by performing a simple Google search using your make, model number and part needed.
I trust this information proves beneficial.
Dec 28, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Where the heck is the drain plug?! Yerf Dog Fun Cart 3203
The drain plug is located under the mower where the blade shaft comes out it may be covered in caked grass clippings scrape them of with a screwdriver or putty knife to reveal the square oil plug.
Aug 07, 2009 | Toro Lawn Mower With Toro Power Tools
Yerf dog go-kart, engine wont rev when gas pettal is mashed
This is probably, a timing problem.
check the plug, and the magneto.
Also, if you haven't already, make sure the air and fuel filters are in good order.
Have fun.
Jul 26, 2009 | Toro Lawn Mower With Toro Power Tools
Recoil rope won't recoil!
-In bnjays case the rope was broken. Sometimes the rope retracks partially or slowly because the surface that the spring edges rub against when retracting the cord, are badly rusted. Disassemble and wire brush the rust off, or leave assembled and spray in thru holes in the pull start with WD40.Avoid getting WD40 on the rope.
Feb 18, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Can't start snowblower with electric start.
Our pull cord broke .came out and now can not thread it back in and when we do cannot do it tight enough . Will not work . Thanking You Linda
Dec 20, 2008 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
2,776 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
