Question about Zenith C27A24T 27" TV
Setup a one for all remote what is the 4 digit code number for my tv I have a 1997 Zenith
    Top Expert:
  • Zenith Master
  • 76,140 Answers
Hello
I've only only one digit code with me. It is "0634". It is the remote code for Zenith HDSAT_420, HDSAT_520, HDSAT_1080. Sometimes this may work with your TV also.
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Posted on Oct 24, 2010
SOURCE:
Zenith menu without remote
Without a remote control, you can't program it. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. For more information; check the links given below, and find which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
For more information, check these links.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Nov 14, 2013 | JVC AV-20220 TV
Need remote code for Zenith TVBR1302Z 13" TV/VHS conbo TV
0573,0729,0183,0791,0472 are the codes to check. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 26, 2013 | Televison & Video
Phillips universal code for zenith tv
Try these codes. 0738,0826,0284,0888,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
Lost remote for zenith H27F56S,so I bought rca universal remote, and have all the codes but still wont work to set up channels.I have followed the set up process to the "T" yet it still will not...
Sometimes the setup procedure might be not right. Check it with an other code. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given. Zenith TVs should synchronize with codes to RCA. Check the number of digit codes, that the TV asks. If it is a three digit one, and you are entering a four digit code, the TV won't synchronize.
Mar 08, 2013 | Televison & Video
Need code for zenith tv
Hello
Three digit universal remote codes for Zenith TV are:
000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153/ 0016/ 0017/ 0092
Four digit codes are:
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Direct Code Entry
Mar 05, 2012 | Zenith Televison & Video
What is/are the remote control scan codes for a Zenith Concierge?
Hello
Three digit universal remote control codes for Zenith TV are:
Four digit univeral remote control codes for Zenit TV are:
Direct Code Entry
Checkout. One amoung the above codes will surely awaken your Zenith TV. OK.
Jul 02, 2011 | Zenith Televison & Video
I need coads 4 my tv
Hello
Three digit remote codes for Zenith TV are:-
Four digit remote codes for Zenith tv are:-
You have to find out which code will suite your tv with patience. Proceedings are given below. Switch on and switch off the tv before trying each code.
Direct Code Entry
OK.
Dec 02, 2010 | Zenith C27A24T 27" TV
TV/VCR no setup key. Where is the setup key? Remote
how do i put TV codes in my SANYO remote it has the number IR 5435 on it dont no if thats the model or not
Feb 13, 2010 | Televison & Video
Need codes for zenith tv
www.rockabilly.net/files/manuals/URC-3220.pdf
Jun 04, 2009 | One For All URC4220 Remote Control
Need code for zenith on urc-3220
016,017,092,000,[COMBO--000,037] are the codes
for your Zenith TV. Follow these instructions
carefully. These are as close as i can get you
to getting you operations...the rest is up to
you. GOOD LUCK!
  1. PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER the 3 digit code for your brand.
  4. You should receive 2 quick flashes after entering your code.
  5. PRESS the POWER button to test the code.
If you have tried all of the set-up codes for your brand of equipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
  1. PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
Blinking Back the Code:
  1. PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
  3. PRESS 9 - 9 - 0.
  4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
  5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
  6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
Mar 03, 2009 | RCA Universal Remote Control
Zenith C27A24T 27" TV Logo
118 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
