Question about Nintendo Wii Console
Wii remote my wii remote not reconising with console
  • Anonymous Dec 28, 2008
    how
  • 52 Answers
You have to click the red button on the inside of the remote and the front were the SD memory card is and it should connect.
Posted on Jun 11, 2008
  • 33 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 03, 2009
3 Suggested Answers
  • 152 Answers
SOURCE: need help programming wii console remote
take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
Posted on Dec 21, 2007
SOURCE: wii remote
open the wii remote battery cover
press the little red sync button once, at the same time as pressing the little sync button under the sd card flap(on the wii) once.
just one tap each and it shud work.
dont keep the buttons pressed or it wont work.
also some people sed to me you can keep '1' pressed
Posted on Jun 13, 2008
Remotes will not sinc
The Wii Remote that came with your Wii console is synced at the factory. Use the steps below to add additional Wii Remotes, or to re-synchronize a Wii Remote with the Wii console. To temporarily use a Wii Remote on another console, see One Time Mode synchronization by clicking here.
Note: how to Make sure you have placed batteries in the Wii Remote.
1. Press the Power button on the Wii console to turn it on.
2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and open the SD Card Slot cover on the front of the Wii console. (The SD Card Slot is the small door located near the disc drive slot.)
3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
5. This procedure must be followed for each additional Wii Remote added to the system.
If your remote for Wii still does not work, the best way is writing to Wii costumer service
Also, If possible, get another Wii remote for a try.
Jul 15, 2013 | Nintendo Wii Console
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Wii will start up and run fine but the wii will not reconise any contol. I had sensor bar tested and it is fine. It hasto be in the cosol itself right?
No the sensor bar just recognizes the position of the remote. If it doesn't recognize the remote at all, it may need to be resynced. Turn on the Wii and the remote. Take the battery cover off the remote. There is a small red button. Now open the small trap door on the front of the Wii. Another small red button. press the red button on the remote first. The blue LEDs on the front will flash. Now press the red button on the console. If the LEDs on the remote stop blinking that means it paired up. Will have to do this for all remotes.
Please Rate!
Apr 08, 2011 | Nintendo Wii Console
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Jan 27, 2011 | Nintendo Wii Console
My wii does not read discs
greasy, eh? There was probably a leak in your console's grase valve (used to reconize disks.) you have to get it repaired
Mar 08, 2010 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
Games wont play says disc error
Replace the laser. This is the cheapest and easiest fix for this problem. You can get one of ebay for under $15
Nov 02, 2009 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Sep 22, 2009 | Nintendo Wii Console
I have a nintendo wii us version and just bought by mistake a wii fitness china version can i get these to work together it won,t reconise the disc.
No sorry. These games are region coded and you have to get region 1 for a US Wii. I suggest trading it in at a game store or selling it on a site like ebay.
Aug 23, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
662 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
