Question about Dishwashers
It' no longer cleaning my dishes - Dishwashers
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
If they are cloudy or filmy
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on Nov 06, 2010
    Genius:
  • 1,417 Answers
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Posted on Oct 23, 2010
SOURCE:
My dishes come out with a gritty sand all over them.
If you live in an area with hard water, the grit is probably hard water deposits. Dishwasher detergents no longer contain phosphate, so the detergents often leave behind hard water deposits on your dishes. There is a great solution at www.cloudydishes.com
Oct 15, 2012 | LG LDF6920ST Stainless Steel 24 in....
My dishes are no longer getting clean. Is it
Hello Sue. There are a few things you can do. let's begin by giving the interior of your dishwasher a good cleaning. To do this, with an empty dishwasher, toss in 2 cups of vinegar and then run your longest and hottest wash cycle. Repeat monthly.
Next, consider changing your detergent over to a product like Electrasol Dishwasher Detergent with Powerball Tabs. That product gets the highest marks from my customers.
Finally, always run the hot water into the sink until it reaches max. temp. before you start the dishwasher. Joe
Thanks for choosing Fixya!
Feb 16, 2011 | Bosch 24 in. SHE43C05UC Stainless Steel...
We bought a new dishwasher because we were finding a hardened residue was being left on our dishes, it was ruining our dishes. Although we have a brand new dishwasher this problem is still occurring and...
My best advise is to reduce the amount of detergent to the least amount that you can use, and still get the dishes clean. We do rinse the dishes a bit, as the soft food disposer isn't made to act like a garbage disposer, but rather, to catch incidental food residues. We no longer fill the closed detergent dispenser. We sprinkle about 1/2 of the normal amount (that goes in the open cup) on the inside door and close it up. Our dishes get very clean, with no residue. Also, use a good drying agent as this will help sheet the water off of the dishes. It may take several cycles to see improvements, but you should see improvements nonetheless.
Best regards, --W/D--
Jan 23, 2011 | Dishwashers
My washer no longer cleans the dishes. the functions all work but it appears that the pump pressure is too low to get stuff off the the dishes.
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dishes no longer get clean dishes always got clean now glasses are cloudy and resr seem dirty always seemed ok before is there a filter or screen yhat needs to be cleaned
May 24, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
I have a Whirlpool GU2600XTPS7 dishwasher - long washing time
You could have a couple things going on here. It could be either related to water temperature, build up in the sensor area or poor washing.
If the dishes are coming clean then you can discount the poor washing.
1st thing to try is clean out the dishwasher, a build up or residue can form on the sensors in the bottom and they can be fooled into thinking the water is cloudier or cooler than normal and it would take longer to heat the water and wash. Here is a link to some instructions I put together on how to clean it out.
Clean Out Procedures
2nd thing to try would be to run the hot water in the kitchen sink until it is hot before you start the dishwasher. By doing this the dishwasher will not have to slow down and pause while it is heating the water enough to clean the dishes
May 01, 2010 | Dishwashers
Dishwasher no longer clean dishes as well as it use to
Hello there
There are several reasons why a dishwasher will start performing poorly and dishes are not getting cleaned here is a list of things to check
It cleans poorly If your dishwasher is cleaning poorly, check these: things that i have listed below by clicking on each one and it will give a description ok? Water-inlet valve Internal filters Drain valve Spray arms Water temperature Detergent cup
I
Apr 02, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher is no longer cleaning properly. A
Clean out the area where food gets caught and consider using different dishwashing tablets - especially the Calgon ones which clean out the drains of teh machine whilst cleaning the dishes.
Alternitivly you should call in a plumber to clean the pipes (Or purchase the equiptment to do it yourself, there are often all-in-one cleaners that'll flush out the pipes)
Dec 24, 2009 | KitchenAid Dishwashers
Dishwashers Logo
361 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
