Question about JVC AV48P776 48" CRT TV
My Tv needs a picture tube. Model numberAV-48P776. This is a JVC Big Screen. Is it possible to repair?
    Brigadier General:
  • 8,909 Answers
A repair is possible assuming a tube can be found. I would google the model number with "tube " after the model, somebody somewhere will have one.
If a tube is still available it is a three man job to change it! The tube is very heavy.
Posted on Oct 23, 2010
SOURCE:
How do i get my HDMI to work on my JVC model av-48p776
Please make sure your TV in on correct channel by pushing INPUT and select [Digital IN]
Jan 31, 2015 | JVC Televison & Video
My pictures have outline
you need to auto converge it if this doesn't work then you need to replace the converge chips
May 27, 2010 | JVC AV-48P775 48" HDTV
Av-48p776 rear projection jvc. power surge from a lightning storm
You will need to replace the convergence chips located inside the set. Typically a repair shop will charge 150-250 to fix it. Good luck
May 16, 2009 | Samsung HC-P4752W 47" Rear Projection...
Dark screen
the sound is locked off the TV good picture
Feb 20, 2009 | JVC AV-27320 27" TV
JVC 48" AV-48P776
no se ve bien los colores jvc 48 776
Nov 02, 2008 | JVC AV-48P775 48" HDTV
JVC TV TROUBLE
If you guys do not have hand soldering skills or know how to use a multimeter, I would suggest to replace the whole assembly.
If you know how to solder you can just replace 2 ICs that are mounted on the big black heatsinks and possibly 1 or more resistors.
Click here to find the entire assembly for your TV.
The link provided is for parts for the AV-56WP74 model ONLY. For the 65 inches; you should contact the vendor and provide the correct model number.
Good Luck.
Apr 22, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
1998 mitsubishi big screen tv model vs-50603
Good Day, bigjim;
No inner tube. The tube may light up but it no video bias to turn the tube on, or the tube is so gassy that it doesn't emit properly.
It sounds like you will be in the market for another TV, because it sounds like like the CRT may be bad.
Hope this was helpful and not tooo late.
Good Luck, big IRISH.
Dec 30, 2006 | Mitsubishi WT-46805 46" Rear Projection...
JVC AV48P776 48" CRT TV Logo
202 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
