Question about Mitsubishi Televison & Video
I have a Mitsubishi Projection Television WD-65736. It has been great, but suddenly after 2 years of use there are grey specks all over the screen when it is turned on. And now today there are bright white specks too.
    Brigadier General:
  • 8,909 Answers
I think if you were to remove the top portion of the set and carefully vacuum the dust off the lenses on top of the crt's, that will fix your problem as it sounds like a layer of dust has settled on the optics.
Posted on Oct 23, 2010
SOURCE:
Blinking status green light red
The most common issue for this TV is the lamp.
If the current lamp in the TV set is around 2-3 years old then I would start with that. If the lamp is not original they only last about 1 year.
If you already replaced the lamp recently the next step is the ballast.
I hope my answer was helpful :)
Oct 08, 2013 | Mitsubishi WD-65736 Television
Status light red
The problem is most likely the lamp.
They usually last 2-3 years if original.
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
I have a mitsubishi wd-65736 no picture just sound
do you have a red lamp light on, if so you need to replace the lamp
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Lamps keep blowing after 12hrs of changing them
If this is a 1 time thing, you may have simply been unfortunate enough to land a faulty lamp. However, if this is has occurred on 2+ lamps... you should replace the Lamp Ballast p/n: 938P127010
Mar 13, 2010 | Mitsubishi WD-65736 Television
Need help with Harmony One remote and Mits WD-65736
To ensure the remote controls your devices properly, you must disable Net Command.To disable Net Command you must delete all devices associated with it.
Open the Mitsubishi Television's setup menu.
Select Delete at the setup menu.
Select Entire Configuration and then select Next.
Follow the onscreen instructions to delete the entire configuration.
To finalize your selections and complete the NetCommand setup, select Finish from the finish screen.
#messageContent0_1 {font:10pt Tahoma,Verdana,sans-serif;}
Feb 01, 2010 | Mitsubishi WD-65736 Television
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL [email protected]
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi wd-65731 ,won't be able to keep it turn on
Call Mitsubishi at 1800-332-2119. Explain the symptom and they should be able to direct you to a service facility that will replace a Temperature Sensor at no charge to you. It is a known failure. Good Luck. Don't wait to call.
Skyassoc
Jul 04, 2009 | Mitsubishi WD-65736 Television
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
