Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Dirty mirror - Akai PTH5498 54" Rear Projection HDTV-Ready Television
    Brigadier General:
  • 8,909 Answers
To clean the mirror and the optics, use a very mild solution of washing up liquid and luke warm water with a clean cloth that when in use is almost dry.
Posted on Oct 23, 2010
SOURCE:
What is the HCP service 101 error code in rocoh prenter modele pro 906 ex?
Exposure Lamp Error
The standard white level was not
detected properly when
scanning the white plate.
• Exposure lamp defective
• Lamp stabilizer defective
• Exposure lamp connector defective
• Scanner motor control unit (MCU board)
defective
• SBU board defective
• Dirty standard white plate
• Dirty scanner mirror or scanner mirror or
lens block out of position
Mar 27, 2017 | Ricoh Office Equipment & Supplies
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Side mirrors work some of the times
I'd start with checking the mirror switch. It's probably dirty or bad.
Mar 27, 2014 | 2002 Buick Rendezvous
I can't find any documentation on how to remove the primary mirror for cleaning. I'm a newb and don't want to mess anything up. Thanks, Bob
First -- how do you know the mirror needs cleaning? Did you shine a flaslight down the tube and see some dust? Never use a flashlight to determine if a mirror is dirty-- they are ALL dirty when you use a flashlight to check them.
Only clean the mirror if it is interferring with the views through the scope.
There is a ring around the back-- remove those screws and the mirror should come out-- don't driop it! Then remove the mirror from the mirror cell.
Sep 03, 2011 | Celestron Advanced C10-NGT (600 x 254mm)...
I have a Tasco 302911 (Old model) D=114mm F=500mm that has been sitting around in the closet for some time. Has become dirty from sitting around and would like to clean up and adjust as required. Would...
The only thing fragile are the main primary mirror and the smaller secondary mirror anything else can be cleaned with Windex and or Pledge.
To learn how to clean the mirrors read this:
http://www.astro-tom.com/tips_and_advice/cleaning_optics.htm#article1
The mirror should be VERY dirty or leave it alone.
You must do this gently or you will scratch the mirror. Once the mirror is clean you will need to re-collimate the scope. Watch this video:
http://www.andysshotglass.com/Collimating.html:
Aug 03, 2010 | Tasco Galaxsee 46114500 (500 x 114mm)...
Receiver end of faxes shows vertical black line. I changed drum and toner also cleaned glass scanner. I do not have a glass flatbed scanner only an automatic feeder.
The cause of this problem is usually a dirty scanning glass (there might be ink or white out on the glass). Check the glass really closely or the cause could be dirty optics or a bad CCD board. There are mirrors underneath the scanning glass. Dirty optics can cause lines when faxing or copying. If you can not access these mirrors, they would have to cleaned by a technician.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 08, 2009 | Brother MFC 4350 All-In-One Laser Printer
Dirty primary mirror
Nice telescope! I clean mine with a dust blaster, those canned air things.They are cheapest from Sam's Club, if you have those near you.Be careful if you decide to use swabs, you may scratch the mirror or remove the special coatings on the mirror.Try the canned air first.If you do use a swab, exercise great care.Use nothing metal.Maybe a long plastic spatula with a soft , lint free cloth.No solvents.Good Luck
Mar 25, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Rear view mirror for 98 chrysler sebring
Try ebay or online salvage stores.
Jan 27, 2009 | 1998 Chrysler Sebring
Phillips
Hi. I had the same problem with my Philips RPTV and the fix is extremelly ease. You just need to open the back cover (mine uses torx screws). Inside the tv is very mechanic. You will find the three CRTs and most likely the lenses are dirty. You just need to wipe them off with a soft cloth. Also the CRTs project the image not directly to the screen, but to a big mirror and that mirror will be most likely dirty (like when you open the hot water in front of a mirror). Once you clean the mirror and the crts, your tv will like as the they you got it.
Jan 24, 2008 | Philips 55PP9502 55" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
