Question about Kenmore 4292x Front Load Washer
Kenmore 40922 front load
I have to replace the baffles in the drum and sears told me to remove the top. spin the drum around to remve the old baffles.how to i remove the top of the washer
  • 413 Answers
This advice from Sears to replace baffles only applies to dryers. The baffles for the washer are installed from inside the basket. If you can't locate mounting from inside the basket, then the entire basket/tub will have to be removed and disassembled.(big job)... But I am pretty sure they mount from inside. Washer or dryer, there are three screws in the rear along the top. Remove screws, slide top toward rear and lift off.
Posted on Jun 07, 2008
How to replace the drum baffles on a Kenmore HE3 front load washer?
Hello Dennis
Appliancepartspros does indeed show an entire kit for EXACTLY YOUR problem... $34
Good time to compare SEARs prices... for those very same parts!!
Happy hunting!!
Sears
Water Filters Lawn Garden Appliance Parts
Appliance parts
http://www.appliancepartspros.com/search.aspx?model=kenmore%20he3t
May 15, 2016 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite oasis 2709 ol signal came up, initially sears repairman said that the drum needed to be replaced so they ordered one and about a week later it showed up, then I wait a week for service guy to...
The "liquid" you here sloshing around in there is supposed to be there,it helps it to stay balanced when it spins at Hightower speed. Also you should use the "clean washer" cycle about once a month,... It helps get rid of the hard water deposits that build up, unless you have a water softener unstaaled in the house - but most people don't. If you do a lot of laundry, the strut rods that hold the drum in place wear out( mine lasted six years) and that will make it out of balance when it goes into drain and spin cycle.
Oct 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore washer model 700, top loading, has a problem with the drum. It seems the drum is let go.it starting jumping around. The washer is only 1 year and 4 months old and warranty expired. Anyone know...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if the "spin tube" that turns the drum has become dis-connected from the "drive block" which locks the spin tube to the drum.
See the following for how to access the tube and drive block.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't need a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked around one of the tabs on the nut and hit the handle of the wrench with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal) instead put a short piece of wood under the drive block and tap the wood up with a hammer.
If the tabs on the drive tube aren't aligned with the slots in the drive block, the tub can move around.
Nov 16, 2009 | Kenmore Washing Machines
Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or...
Hi.
I
f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Kenmore 44042 Front Load Washer
Kenmore Oasis becomes unbalanced all the time
Its a tricky repair. there is a spring that sits on the base of the motor. You need to remove the pulley and plastic gears to gain access. This spring is slipping causing drum not to spin correctly. Remove it and clean properly with solvent . If broken replace. Reinstall and retry.
Sep 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Mar 29, 2009 | Kenmore 44072 Front Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Drum does not turn
THE BELT HAS BROKEN,TO REPLACE REMOVE THE 2 LINT SCREEN SCREWS,PULL THE TOP TOWARD YOU AND UP,REMOVE THE 2 SCREWS FROM THE TOP FRONT PANEL ONE ON EACH SIDE,REMOVE THE DOOR SWITCH WIRES,PULL THE FRONT UP AND OFF,PUT THE NEW BELT AROUND THE DRUM AND UNDER THE DRUM PULLEY AND ONTO THE MOTOR PULLEY,PUT ALL BACK TOGETHER,YOU CAN GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR,GO TO YOUR LOCAL APPLIANCE PARTS STORE TO GET A BELT,OR GET IT FROM SEARS .COM
Mar 08, 2009 | Kenmore 63942 Dryer
Replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Aug 09, 2008 | Washing Machines
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 4292x Front Load Washer Logo
266 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
