Question about Cell Phones
My samsung c300 says limited service and i cant send or receive calls and texts and i dont know the default call barring code
SOURCE:
smilemaker
  • 790 Answers
SOURCE: text messaging
Check the message center no .. it might me wrong !!! Call ur customer care and verify the message centre no!!
Posted on May 22, 2008
  • 1257 Answers
SOURCE: incoming calls barred
Goto settings there you will see a option "Restore to factory settings" .Try it and let me know if this fix the issue.
Posted on Oct 25, 2008
Bajanguru
  • 7752 Answers
SOURCE: My phone won't send/receive calls or txts. NO SERVICE
what you need to tell the service provider is that to delete the vLR on they network then add it again
Posted on Jun 01, 2009
SOURCE: samsung sgh-e590 limited service
HI i have same problem with my samsung.
Posted on Jan 04, 2010
SOURCE: "Check Operator Services" when sending a text
most probably you have disabled the CLI thing. In which your cell tries to prevent your number being shown to the person you are calling.
It is usually under Network settings, or Call settings (CLI/Show my number/Send my Number).
Posted on Feb 27, 2010
Cant send text messages
call your service provider they will send you a setup message for your mobile including the message center
Nov 15, 2013 | Samsung Galaxy Exhilarate SGH-I577 AT&T
I can't make or receive call nor text on my nokia c300
Is the network bar shows OK ? Do you have enough balance to make a call ? And what about the validity ? First check all this, and if you found correct insert the sim to another phone and try.In other phone if the sim works perfectly,Restore your phone by typing *#7870# when your phone is in stand-by mode.Good luck
Mar 08, 2012 | Nokia C3 Cell Phone
I have a nokia 2730c, my number is currently barred, do you know what the code for cancelling the barring? Thank You
hi,
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 | Nokia 2730 Cell Phone
How can i unlock the samsung c300 phone
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 1122 or 000999
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Oct 05, 2010 | Samsung SGH-C300 Cellular Phone
My friend has given m an old samsung c300 and soon as i turn it on its asking fora pin. My friend said there isnt one, but i dont have one. Is there a way to bypass it? cheers, J
is it asking for a PIN code? try using 0000 or 00000000. If it doesn't work the default code must have been changed, try to call your service provider to provide you the PIN code for the phone.
Jul 03, 2009 | Samsung SGH-C300 Cellular Phone
Can't make calls, texts won't work.
soft ware problem and virus install kaspersky
May 30, 2009 | Samsung Propel A767 Cell Phone
Sch c300 calls not coming through
sounds like call fowarding has been set try deactivation cfw feature / default codes are usualloy 0000 1234 12345 etc refer to your user manual or online service provider info
Mar 31, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Cant call or receive calls!
hi,
if you take the phone back to the shop you bought it rom they should fix it.
Mine was doing the same thing so i took it back last week. Picked it up yesterday and it seems to be working fine. Guy said there is a software fault with these phones...
Feb 17, 2008 | Samsung SGH-U600
Have full signal but...
Did you try a mester reset?
Dec 16, 2007 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
103 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
